Win 98 SE does not want to copy files > 2G and <4G. Does anyone know of a patch or a copy utility that will work short of a new OS?
Right click your hard drive, and select properties. Look at the file system. If it is FAT, than upgrade it to FAT32. Windows98 comes with a program that will do that for you in accessories/system.
I already have a fat32 file system. Windows Explorer posts an error when I try to copy. I can look at the error message at this time.
what are you copying that is more than 2gigs? If it is a vob file from a dvd i think you have to use software programs to copy them.
if I can be of any help, you need at least 4G of free space on your HD to be able to copy over 2G file...
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo -
The problem isn't with your configurations but with windows itself. You need to upgrade to an NTFS file system....WIN XP or 2000....they can support files over 4gigs. I know because I have a mpg2 encoder card and ran into that problem with win98 so I used partition magic to resize my partition on C:\ by half and then create an additional one thus ending up with C:\ and D:\ so install win 2000 and do the duel boot option. Choose the new partition D:\ to install it to. Thats the only way....you would not even be able to crate smaller files and then join them up....cause as soon as you hit 4 gig file size the application crashes. The 4 gig file size is only set for 1 file being that large. Upgrade to XP or WIn2000 both must be installed with a NTFS file system....and remember if you run the duel boot WIn98 will not see the files on D:\ because it can not see NTFS files stucture but a NTFS can see the fat 16 or 32 files....so win2000 or XP will see your 98 stuff. Hope this helps. I now it did when I ran in to that problem.
I get the same message copying files larger than 2gig (not 4gig) in win98. The error message is "can not copy or replace, the parameter is incorrect". I think it's a problem in win98 and windows explorer. Open a ms-dos window or boot to dos mode and then you can copy.
cannot copy files to computer or copy dvd
By moshik16 in forum Newbie / General discussionsReplies: 0Last Post: 14th Feb 2010, 16:09 -
ipod touch video playing at 2x or greater?
By extremelyslow in forum MacReplies: 0Last Post: 3rd Feb 2009, 17:41 -
Music volume is greater than people speaking
By Alvito in forum AudioReplies: 3Last Post: 24th Dec 2008, 17:23 -
I have to ask again, trying to installing Win98.
By capman21 in forum ComputerReplies: 45Last Post: 23rd Jun 2007, 12:38 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
