just found my jvc mini dv camera today i hardly used it has one tape in the camera only recorded 2mins of video on it to test camera to see if its working fine and it has no problems at all and takes really hq video for SD 16:9 576i video
rather then get a new camera that uses sd cards i would like to use this camera and wanted to know how many times i can record over a mini dv tape before it goes bad ? i know mini dv tapes are cheap to buy i can get a pack of 3 from ebay that works out to be $4.21nzd a tape
but i would like to get the most out of my first tape before i spend money to get more tapes as i don't really record videos that often to make it worth spending more money
I've been using (and still using) MiniDV for many years and I'd say if you record over the same tape more than twice you are risking a drop out here and there occasionally, nothing major but it would annoy me. So it's your choice.
Personally I record every tape only once and keep the tapes as master backups – something not to forget about. Tapes are a reliable long-term storage media if treated properly.
Oh and better don't use LP. Ever. -
I agree with Skiller. Even expensive tapes are "cheap" when compared against losing irreplaceable memories.
Don't want to sidetrack, but given the change in camcorder selection in the marketplace, I wouldn't consider tape-based archives to be that safe a medium. Even if the tapes remain pristine, they're no good to you if you cannot play them back later (without undue $$$ outlay). Something to consider.
If you DO intend to remain using DV/HDV, these are my rules of thumb:
1. Don't use LP ever.
2. Don't use 32k, except in extreme circumstances. Basically ever.
3. If your camera gives you the option of using 44.1k, don't use it.
4. Only use 16:9 widescreen in cameras that actually use the full picture with anamorphic pixels, otherwise you're hard letterboxing.
5. Stick either with tapes from one manufacturer religiously, or cycle through tapes from many manufacturers, but don't use mainly one mfr and then occasionally switch over (has to do with tape lubricant gunking up the machine).
Need help archiving some old DV Mini tapes
By donaldc48 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Nov 2014, 22:44 -
Mini Dv Tapes not playing correctly
By Billjosh in forum Newbie / General discussionsReplies: 8Last Post: 16th Apr 2014, 17:19 -
Have Mini DV Tapes but no camera and want video
By miss teri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Apr 2013, 12:49 -
Transfer mini DV tapes to PC and then to DVD
By Happyfeet2 in forum Newbie / General discussionsReplies: 19Last Post: 9th Mar 2011, 08:34 -
Uploading mini dv tapes to cloud
By boke in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2011, 11:38
