Is this possible ? If possible, then what should i do ?
I think you'll find what you are looking for here:
http://www.labdv.com/en/examples/svcd_audio.htm -
what i don't think it says there is that only a very few players can recognize MPEG-5.1, even fewer receivers can decode it (some european models, some high-end kenwoods), and that even if you have both pieces, it's not necessarily the case that the DVD player can output the signal when it sees a CD instead of a DVD (like mine, a pioneer 343)
This has been discussed tons of times. As others have stated, SVCDs do officially support multi-channel MPEG audio but few DVD players support this.
In essence, this is hard to make and probably won't work. I would just stick to Dolby Surround stereo.
Regards.
Michael Tam
w: Morsels of Evidence -
if you really want 5.1 though miniDVD or cDVD is the way to go for that. but almost no players support this. wait until you get a dvd-rw
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
