I captured some MiniDV tapes using Premiere CS5 and Windows 7 64bit. I captured the entire tapes, but now would like to break them into sections. In Premiere I selected Microsoft AVI and the Video Codec Uncompressed UYVY 4228 bit. This increases the size of the original captured AVI. Is there a way to keep the original captured file size after making simple trims/edits while retaining the quality of the avi for possible future editing.
been awhile since i used cs5 but i believe it does smart rendering of dv. select you project as dv and output dv. no re-rendering is done.
By output DV does that mean select Format Microsoft AVI and then Codec DV NTSC?
sounds right
You don't want to convert to lossless without knowing how the 4:2:0 is color upsampled to 4:2:2.
And you don't need to.
Keep it as DV from edit start to edit end. Since it is all I-frame, ALL edits and sections will smart-render (with most good editors, incl. Premiere). Only edits that have color correction, titling, fades, compositing, etc., would even re-encode in the render.
Scott -
For simple cuts with DV, using an editor like that is overkill IMO. VirtualDub will cut them easily, quickly and losslessly (Video->Direct stream copy), and of course make sure for audio too (Audio->Direct stream copy).
I hate VHS. I always did.
Quality Issues When Converting Captured VHS Footage, Need Help!
By kjw873 in forum Newbie / General discussionsReplies: 8Last Post: 15th Jan 2014, 21:32 -
Problem with editing captured game play footage
By shane1123 in forum EditingReplies: 5Last Post: 8th May 2013, 11:04 -
captured footage, now notice a line throughout frame
By Ray S in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2011, 11:38 -
Gameplay footage with minimum quality loss
By dBallaz in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2011, 08:02 -
HELP - Need software for mac that can trim/cut clips without quality loss
By someone04 in forum MacReplies: 6Last Post: 3rd Mar 2011, 19:06
