I've noticed that motion in mkv or mp4 format often fatigues my eyes like
it is skipping frames or something.
I've downloaded the same TV show in avi and mp4 format.
Motion when viewing the avi version seems consistently "easier on my eyes".
The mp4 in my example is twice the size so you would think it would have
more better motion but it doesn't. Both show the same frame rate 29.970
Can someone help me understand why? Does AVI encode motion better?
Here are the specs for each video. Based on the specs maybe someone help
me understand why avi seems to display smoother motion? Thanks...
The MP4:
The AVI:Code:Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 638 MiB Duration : 45mn 13s Overall bit rate mode : Variable Overall bit rate : 1 973 Kbps Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 45mn 13s Bit rate : 1 841 Kbps Maximum bit rate : 5 012 Kbps Width : 832 pixels Height : 464 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.159 Stream size : 595 MiB (93%) Writing library : x264 core 66 r1092 60f4cd8 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.1:0.0 / mixed_ref=0 / me_range=16 / chroma_me=0 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1841 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=14000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Code:Format : AVI Format/Info : Audio Video Interleave File size : 350 MiB Duration : 44mn 49s Overall bit rate : 1 091 Kbps Writing application : VirtualDubMod 1.5.10.2 (build 2540/release) Writing library : VirtualDubMod build 2540/release Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (MPEG) Codec ID : XVID Codec ID/Hint : XviD Duration : 44mn 49s Bit rate : 951 Kbps Width : 512 pixels Height : 384 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.161 Stream size : 305 MiB (87%) Writing library : XviD 1.0.3 (UTC 2004-12-20)
	Container should have no bearing on viewability (barring individual system setup inadequacies).
 Since both are 29.97p and both ~SD, it's more likely some difference in content preparation: frame blending, telecine...
 Or bitstarving/compression artifacts.
	I agree. If both were encoded to a decent quality there shouldn't be a difference in terms of motion due to the encoding itself. If they were originally 59.94fps interlaced and de-interlaced to 29.970 progressive for encoding, the de-interlacing quality might be more of a factor.
 NTSC with badly (or incorrectly) removed pulldown can also be a cause of not so smooth motion (pulldown is used to convert film to 29.97fps NTSC). You can end up with frames being repeated occasionally while others are removed when they shouldn't have been.
 https://en.wikipedia.org/wiki/Three-two_pull_down
	I think this is what I am seeing. Motion seems to split second pause then it jumps as if
 frame 1 is repeated, 2 is missing, then 3 comes along. But with 30 frames per second
 I wouldn't think the human eye could notice.
 Yet when I eyeballed both versions of the TV show, I watched a slow pan of the
 camera across a scene, the avi was smoother while the mp4 had a constant stuttery
 look to the motion.
	That's not 3:2 pulldown. But there is virtually no 30p content. So what you have is most likely film content that has gone through 3:2 pulldown for TV, then badly deinterlaced to 29.97 progressive.
 You can easily see repeat/deleted frames at 30 fps.
 Jerky playback has nothing to do with the MP4/MKV containers or the codecs used. It's how 24 frames per second film sources were converted to 59.94 interlaced fields per second for broadcast, then deinterlaced to 29.97 progressive frames per second.
 http://www.100fps.com/
	You could use a player such as MPC-HC to step through the frames one at a time to maybe get a better idea as to what's going on. Maybe open each version in a different instance of the player and step through them one frame at a time while comparing them to see what's different.
 I've seen a reasonable amount of video that was originally film converted to NTSC where field matching was applied when it was re-encoded, but not decimated, so it ends up 29.970fps progressive with every fifth frame repeated. Either that or it was just created that way. That tends to be far more noticeable in respect to jerky motion than pulldown, at least to me.
 Maybe it was simply a case of the video not being decoded correctly when the MP4 version was being encoded. Or maybe they were taken from different sources and the MP4 was taken from a bad capture, or the source had atrocities inflicted on it when it was broadcast.... being a TV show.
 Co-incidentally, someone sent me a PM with a link to a sample they were trying to encode yesterday. The encode looked very "jittery". Stepping through frames there was a fairly consistent pattern of 3 unique frames, one repeated, two unique frames, one repeated.... but there were frames missing too as the frame rate was correct. The odd part was the source was simply 23.967fps progressive and I had no trouble re-encoding it, so for them it must have been a decoding issue (they were decoding via DirectShow).
	Looking closer, it seems the avi is also using mp4 so it must be all in how
 it was encoded. (which I did not do)
 Another angle to consider, is it possible that my WDTV that I use to
 play it on my TV is lacking the house power to play highly compressed
 video smoothy? Or does the compression aspect have no effect when
 being played back?
  How to demux WMV8 file ..to any other format like MKV,MP4 without losing qBy prithvi in forum EditingReplies: 6Last Post: 7th Jan 2015, 07:19
  Format Factory MKV to MP4 problem with videoBy NerkoJVG in forum Video ConversionReplies: 6Last Post: 20th Apr 2014, 08:52
  judder and motion smoothing problem in mkv format in my brand new laptop.By cercig in forum Software PlayingReplies: 4Last Post: 25th Sep 2012, 22:22
  Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issuesBy Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
