Results 1 to 12 of 12
  1. Hello friends
    Me by a webcam. Avi format movie I saved. Time video and audio, but 55 minutes is 38 minutes.
    So the film is played at high speed. I ask for help from friends Is there a solution for improving video and audio. Please advise
    ThanksClick image for larger version
    You can try change the framerate/fps with virtualdub, open your avi, select Video->direct stream copy, Audio->direct stream copy and then Video->Frame Rate and try different values(like same fps as your first avi). Last File->Save As.
    And if that fails post the details from your avi with mediainfo, open avi, choose view->text and copy everything.
  3. tnx for answerClick image for larger version
ID:	33892Click image for larger version
    General
    Complete name : J:\New Work\Videoclip2.avi
    Format : AVI
    File size : 481 MiB
    Duration : 55mn 3s
    Overall bit rate : 1 221 Kbps
    Video
    Format : MPEG-4 Visual
    Codec ID : MP42
    Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard)
    Codec ID/Hint : Microsoft
    Duration : 55mn 3s
    Bit rate : 214 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 5.000 fps
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.021
    Stream size : 84.2 MiB (18%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 38mn 24s
    Bit rate mode : Constant
    Bit rate : 1 411.2 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Delay relative to video : 27ms
    Stream size : 388 MiB (81%)
    Alignment : Aligned on interleaves
    Interleave, duration : 358 ms (1.79 video frames)
    But can you change the fps and save in virtualdub? Ignore the warnings.
  5. The sound files are all corrupted. That's why the impact on video
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    So you can't save?
    Try reconvert the audio, select Audio->Full processing mode in Virtualdub.
  7. "Try reconvert the audio, select Audio->Full processing mode in Virtualdub."
    What do you do . i'm amateur
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Open avi.
    Select Video->Direct Stream Copy.
    Select Audio->Full Processing mode.
    Select Video->Frame rate. Set it to 25fps for exapmle.
    File->Save avi.
  9. not work . timeline from 55 min Was reduced to 11 minutes.
  10. Does that sound and separate film later amended program
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Looks like you should lower the fps....try 3 fps.
  12. Frame rate to 3 lower
