Hi, I'm editing a GOP in one of my videos so that I can concatenate it with another video. To better define it I have videos A and B. I am removing part of A and encoding (from the source, not a re-encode!) the end of the current scene since the GOP I want to cut on does not terminate at the end of the scene. As such we have this new video C that tacks on to the end of A (after being trimmed) and then B is concatenated as well:
A (trim'd) + C + B
Video C is encoded using the same x264 settings (encode settings, level, etc.) as well as the same x264 version as both videos A and B. When I append them in mkvmerge I get:
K01-Ending is video C which I just encoded from the source; what can I do at this point (given that every setting matches) to correct this? I know if I just append them as h264 I get no warning but I feel that something still isn't right.Warning: The track number 0 from the file 'F:\Output\K01-Ending.mkv' can probably not be appended correctly to the track number 0 from the file 'F:\Output\K01-Main.mkv': The codec's private data does not match (lengths: 45 and 43). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file.
Warning: The track number 0 from the file 'F:\Output\K01-Preview.mkv' can probably not be appended correctly to the track number 0 from the file 'F:\Output\K01-Ending.mkv': The codec's private data does not match (lengths: 43 and 45). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file.
Results 1 to 25 of 25
Using --stitchable on the commandline will increase your chances... But it doesn't always work
The 100% foolproof way is to cut on GOP boundaries (make sure they are IDR frames, true delimiters, not "i" frames) . And use --sps-id of a different number for the middle segment e.g. --sps-id 2 . Then do a dos binary join on the 3 elementary streams. Then you can re-wrap with audio into a container -
i'd encode all parts to lossless avi, then edit and re-encode to final.
Stitchable is not accessible in this version (r2334 current, r2342 it was implemented). I did test with a later version with stitchable and it had some artifacting but the same message remained. I am currently cutting on the GOP boundaries which is why video C currently exists as the the frame I wanted to cut on was mid GOP and I can't do that properly so I cut on the GOP prior to it and then encoded (from source) where the following GOP without the unwanted frames. I also tried specifying a different sps-id in an encode but we still arrive at the same issue. All these issues disappear doing a binary join with my current material but it doesn't seem right to do this unless the codec issue is strictly in the mkv and not the h264 stream itself.
I would rather avoid any further encoding, several filters were applied to various scenes and I do not know which ones they were. Otherwise the simplest solution would be to redo the video.Last edited by Elegant; 30th Sep 2015 at 00:13.
You won't get that message or any errors if you do the binary join. That' s how distributed encoding is done (e.g. youtube over multiple servers) - it has nothing to do with MKV or any container.
Results from mkvmerge (using h264 files not mkv) appear to be the same as the binary join (used HxD) for what it does for elementary streams. I guess I'll just roll with this, thanks.
When I double check these new files in an AviSynth editor/preview mode I see some "artifacting" on the initial and final frames of interim clip (video C) but I don't see them during playback (Maybe they'll appear if I try to start playback from that point?). Is this just an issue with FFVideoSource trying to interpret the file or is there something else I'm not considering? -
This indicates a problem - Which shouldn't happen
Are you sure you did the procedure correctly? This suggests you didn't cut on IDR boundaries
It only fails if you don't do a binary join, or didn't use GOP boundaries. Or the artifact was there in the first place in your re-encoded C. Or you used open-GOP in your "C" section (heh C-section LOL). The first frame should start with an IDR frame
If you still can't figure it out, upload the section around the original source files (at least 2 GOPS away), your encode and result -
Okay, I've recreated the scenario with clips A, B and C as was initially described. A and B are 2 GOPs away from the interim C clip that joins it all together. They are in mkv format (currently) but when concatenated (see A+C+B) you should see the issue in any AviSynth editor with FFVideoStream. Also, I wouldn't call "C" a re-encode since it is from the source material and not from the already encoded video.
Clip A
Clip B
Clip C
Clip A+C+BLast edited by Elegant; 30th Sep 2015 at 19:39.
I see the problem in A+C+B, right at the "seams" .
But what is your A+C+B ? Is that your with your Clip C re-encoded with 10bit AVC using similar settings ? with different --sps-id , binary join?
Please say you used 10bit AVC for the C re-encode ?
Anyways it works fine here . Perfect, no glitches
If you need detailed instructions, I'll try to walk you through it -
C is a encoded from the original source using the same x264 version (r2334 10bit) and settings as A and B to the letter (which are also encoded from the original source) but does not include a different sps-id as it literally made no difference in this scenario. This is also a binary join with A+C+B but I cannot seem to get rid of that problem at the seams.
Were you able to combine them without the issue occurring at the seems? -
Yes it works fine .
1) I extracted with mkvextract. It gave me (you don't actually have to extract C, because you are re-encoding it)
A_track1_eng.h264
B_track1_eng.h264
C_track1_eng.h264
2) I created FFMS2 script for track C. Make sure the preview is correct (some versions of FFMS2 might be buggy)
3)Code:FFVideoSource("F:\_Video Tests\sps-id\C.mkv") AssumeFPS(24000,1001)
I re-encoded C with 10bit x264 using x86 version because I'm too lazy to pipe (direct avs input)
I set the --sps-id of 2 hereCode:x264k10_32 --level 4.1 --profile high10 --force-cfr --fps 24000/1001 --bitrate 8000 --b-adapt 2 --deblock -1:-1 --sps-id 2 --sar 1:1 -o C2.264 C.avs
You can actually use different encoding settings . But there are a few other obscure conditions that can make it fail. --sar is one of them that can cause problems with some decoders when it switches mid stream. It was 1:1 not "undefined" in A and B. It doesn't even matter if the same x264 version or core was used. Or different encoder even.
You can use h264_parse to list some other settings if you don't recall what you used or don' t know in the other files. But mostly it doesn't matter what settings you use
The other situation is it may break VBV constraints - e.g. some situations where VBV is important like BD . If your stitched segment has much higher bitrate or some high peaks, theoretically it might cause buffer underruns . This won't affect FFVideoSource or computer playback
When I said 100% success - I meant 100%. There is no reported failures in 8-9 years since this method has been around. It's just "clunky" and cumbersome to do. The most common cause of failure is not cutting on GOP boundaries correctly
4) I renamed "C2.264" to "C2.h264" Probably not necessary, but just to match whatever mkvextract extracted
5) Next I joined in a specific order. The newly appended file takes on the --sps-id of the first file. I don't know if this is necessary either, but this is the way I do it and it never fails. My thinking is if I append A+C, that will have sps-id of zero. If I join (A+C)+B, zero and zero will have problems
So instead, I join C+B (so (C+B) now has sps-id of 2, then A+(C+B) . zero and two are ok, because they are different
so "new.h264" is the final file. You can use mkvmerge or whatever muxerCode:copy /b c2.h264 + B_track1_eng.h264 cb.h264 copy /b A_track1_eng.h264 + cb.h264 new.h264
I might have missed some steps, but I posted this before in another thread, there might be more detail thereLast edited by poisondeathray; 30th Sep 2015 at 21:06.
I'm trying to get on the same page as you so I'll outline my steps (these steps are not solving the issue currently):
1. Extract h264 streams from A and B track.
2. I create a script for track C as follows:
3. I encode C using the following:Code:DGSource("E:\Output\00000.dgi",fieldop=0) AssumeFPS(24000,10001) Trim(36401, 36635)
4. I join C with B and then CB with A.Code:avs4x264mod --x264-binary "x264-10b_64" --seek-mode "safe" --colormatrix bt709 --level 4.1 --profile high10 --force-cfr --fps 24000/1001 --bitrate 8000 --b-adapt 2 --deblock -1:-1 --sps-id 2 --sar 1:1 -o "F:\Output\K01-Ending.h264" "E:\Output\K01-Ending.avs"
5. View in editor to see my problem still exists.Code:copy /b C.h264 + B.h264 CB.h264 copy /b A.h264 + CB.h264 Final.h264
I can't reproduce your problem (when using the proper steps)
I used komisar's x264 build, but I doubt that will make a difference .
http://komisar.gin.by/
I'll upload my "C" re-encode (which is "c2.h264") and try to repeat the steps with appending on the same sample files (step #5 in my post)
Your samples should be long enough to reproduce the problem, so I don't know what is going on -
x264 core 133 r2334 a3ac64b
10 bit version; this is what A and B were encoded with originally. -
But is it a "vanilla" version or what patches were applied? Did you build it yourself , or where did you get it ?
That's a good question... perhaps I should try and hunt it down again. Mind you most copies online are currently 8bit only.
It actually shouldn't matter which version you use, as long as the output bitstream conforms to AVC standard. There is a lot of "wiggle room" here. If it didn't work, it suggests that the output of that binary is buggy
Yeah, I'm a stickler though for making sure this stuff matches up. I'll browse a bit for another x264 10b r2334 unless someone still has it lying around. Thanks for the help though!
32bit
http://x264.nl/x264/?dir=./32bit/10bit_depth/revision2334
64bit
http://x264.nl/x264/?dir=./64bit/10bit_depth/revision2334
These are "vanilla" builds from the old x264.nl host -
Yep, I just finished encoding as I refreshed this page XD All good here! Can't believe that was the issue. Thanks!
One last question, you mentioned that A and B had SAR 1:1 but C had it as unknown. I could not find that using MediaInfo what's the best way to determine that info? -
The free way is to use h264_parse ; I mentioned it above. or You can use various stream analyzers, but they are pretty expensive
e.g for "A", this will output to a text file
The portion that indicates sar is this:Code:"h264_parse" "A_track1_eng.h264" 1>A.txt
Code:vui_parameters_present_flag: 1 aspect_ratio_info_present_flag: 1 aspect_ratio_idc:1
If you run it on "C" it looks like this which is "undefined"
Code:vui_parameters_present_flag: 1 aspect_ratio_info_present_flag: 0
codec private data issue - ffmpeg CRF15 and CRF18 in MKV files
By jack616 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2015, 15:32 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
"all new posts here" view doesn't match.
By Hoser Rob in forum FeedbackReplies: 2Last Post: 23rd Apr 2013, 12:51 -
How to edit "info.dvr" + How to match a particular MPEG format with FFMPEG
By falco2000 in forum Video ConversionReplies: 8Last Post: 27th Sep 2012, 12:00 -
mmg problem ( The codec's private data does not match)
By Umen Pich in forum EditingReplies: 6Last Post: 19th Sep 2011, 23:32
