Hi guys, i have a quick question about Megui encoding, i encoded a 1080p Bluray mkv file as always, at the end of the encoding i set the file size to 1.1GB with approximately bitrate 1660 Kbps (source 10 Mbps and is 1h 30mn long). But after encoding i got 2.6GB instead of 1.1GB for the final file. Never happened this before i always got the size which was set. So why is this happening, can someone give advice? (also tried with 1GB and 1.2 and 1.3GB but i get always a too high size 2.7GB) Thx in advance
Results 1 to 20 of 20
Have you checked the runtime of the encoded video? So it's same as the original.
What is the audio bitrate? -
Audio bitrate is 384 Kbps 5.1 -
Today i tried once again but with no success, then i checked the video bitrate and it was surprisingly 3860 Kbps. When i set the file size, megui showed me an average bitrate of 1800 Kbps. So this is the reason why is the size of the encoded movie so big, but i still dont understand it why it is happening. Maybe this helps for better overview.
Indeed, very suspicious details...
Code:---[Information] [10/1/2015 12:46:48 AM] I frames: 852 frames, size = 29030/ 24733602, quants = 1 / 1.00 / 1 ---[Information] [10/1/2015 12:46:48 AM] P frames: 47691 frames, size = 21927/ 1045743137, quants = 1 / 1.01 / 2 ---[Information] [10/1/2015 12:46:48 AM] B frames: 87367 frames, size = 18511/ 1617254152, quants = 1 / 1.02 / 3 ... ---[Information] [10/1/2015 12:46:50 AM] Video Bitrate Desired: 1813 kbit/s ---[Information] [10/1/2015 12:46:50 AM] Video Bitrate Obtained (approximate): 3798 kbit/s
Is there a reason to use "turbo mode" in pass 2? This option is clearly designed for pass 1 only. -
LigH.de, you might be right. IIRC Xvid had a rate contol problems if max quantizer is set to 1. Reducing max quant to 2 for all frame types might help.
Hi guys , thank you both for help.
xvid_encraw seems to "get cramps" trying to encode with quantization 1 in pass 2.
LigH.de, you might be right. IIRC Xvid had a rate contol problems if max quantizer is set to 1. Reducing max quant to 2 for all frame types might help. -
Not only that, you also seem to use a quite outdated version, so I wonder if you still prefer using the "stable" version of MeGUI; switching to the development updater will give you much more recent tools (maybe a few recent bugs too, but they are usually fixed quickly).
And don't just install a newer XviD on top of an already installed older version. First, use Add/Remove Programs to uninstall the older version and then install the more recent version.
Well, he could possibly exchange xvid_encraw in a "stable" installation of MeGUI, but I won't guarantee that the command line parameter set is still 100% compatible, most probably some parameters may have changed their value range in details between v1.2.2 and v1.3.4.
Too big size of AVI file.
By SekhmetPL in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2013, 11:24 -
MP4 is to big. How can I lower the size?
By DonGallego28 in forum Video ConversionReplies: 6Last Post: 16th May 2013, 03:11 -
Strange video shift when set to big size
By peaceDOThuxDOTde in forum DVD RippingReplies: 1Last Post: 10th Jan 2012, 07:26 -
size of my VOB reduced after re encoding
By mathmax in forum Authoring (DVD)Replies: 11Last Post: 14th Dec 2011, 21:27 -
laptop screen size too big
By angryassdrummer in forum ComputerReplies: 7Last Post: 14th Feb 2011, 22:20
