Hi There,
i'm struggling with MKV merge/toolnix.
Its an wonderful program, but now at this moment its killing me.
I would like to merge an intro mkv file in an existing mkv video file.
The thing is, it merges like it supposed to do but wen i play the mkv file with my player it doesnt show the intro.
I have tried several things, sometimes it plays the intro but then the video film itself seems to be playing fast forward.
What am i doing wrong? Or is it even possible to doe with mkv toolnix?
if someone can help me out then i wil be pleased like ...
Funny thing this, if i place an attachment file, Jpeg then the jpeg is shown in my player, but with an other mkv video it wont play.
Greetz Nozem013
Most likely there is a mismatch between the intro video and the main video -- frame rate, dimensions, codec, level, or any one of dozens of other variables. You can post MediaInfo reports if you want help comparing them. Even the queue window in MKV toolnix will show many of the basics.
Do you use the append-button in mkvmergegui? Or else are you making a mkv with several video tracks.
Does it play okey on your computer? -
im using the append button indeed. On pc also not playing okay like i hoped it would play.
i have the media info of the intro and movie here for you guys, hopefully you can help me out
INTRO FILE:
Algemeen
UniqueID/String : 61029063379351632940621636260499888100 (0x2DE9C522EA65A206FF8FF29DDBC917E4)
Volledige naam : C:\Users\libra\Downloads\LRT intros\Intro L.R.T. HDx264.mkv
Formaat : Matroska
Formaatversie : Version 2
Bestandsgrootte : 17,4 MiB
Duur : 12s 54ms
Totale bitrate : 12,1 Mbps
Gebruikt programma : HandBrake 6548svn 2014112401
Gebruikte encoderbibliotheek : Lavf55.12.0
Video
Formaat : AVC
Formaat/Info : Advanced Video Codec
Formaatprofiel : High@L4.1
Formaatinstellingen, CABAC : Ja
Formaatinstellingen, ReFrames : 7 frames
Codec-ID : V_MPEG4/ISO/AVC
Duur : 12s 54ms
Bitrate : 12,0 Mbps
Breedte : 1 920 pixels
Hoogte : 1 080 pixels
Beeldverhouding : 16:9
Frameratemodus : Constant
Framerate : 23,976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scansoort : Progressief
Bits/(Pixel*Frame) : 0.242
Stroomgrootte : 16,5 MiB (95%)
Gebruikte encoderbibliotheek : x264 core 142 r2479 dd79a61
Instellingen codering : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=12031 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Ja
Forced : Nee
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
colour_range : Limited
Audio
Formaat : AC-3
Formaat/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Formaatinstellingen, Endianness : Big
Codec-ID : A_AC3
Duur : 12s 54ms
Bitrate-modus : Constant
Bitrate : 384 Kbps
Kanaal(en) : 2 kanalen
Kanaalposities : Front: L R
Samplerate : 48,0 KHz
BitDepth/String : 16 bits
Video vertraging : 27ms
Stroomgrootte : 565 KiB (3%)
Titel : Stereo
Default : Ja
Forced : Nee
VIDEO FILE:
Algemeen
UniqueID/String : 195283719059805899925828056230276065227 (0x92EA46B647739C288CC9352E30DB67CB)
Volledige naam : C:\Users\libra\Downloads\..............mkv
Formaat : Matroska
Formaatversie : Version 4 / Version 2
Bestandsgrootte : 3,51 GiB
Duur : 1h 56mn
Totale bitrate : 4 336 Kbps
Datum codering : UTC 2015-09-14 07:37:33
Gebruikt programma : mkvmerge v6.7.0 ('Back to the Ground') 64bit built on Jan 8 2014 15:10:52
Gebruikte encoderbibliotheek : libebml v1.3.0 + libmatroska v1.4.1
Video
Formaat : AVC
Formaatprofiel : Main@L3.1
Formaatinstellingen, CABAC : Nee
Formaatinstellingen, ReFrames : 2 frames
Duur : 1h 56mn
Bitrate : 3 865 Kbps
Breedte : 1 280 pixels
Hoogte : 538 pixels
Beeldverhouding : 2,40:1
Framerate : 24,000 fps
ColorSpace : YUV
Bits/(Pixel*Frame) : 0.234
Stroomgrootte : 3,13 GiB (89%)
Taal : Engels
Default : Ja
Forced : Nee
Audio
Formaat : AC-3
Codec-ID : A_AC3
Duur : 1h 56mn
Bitrate : 384 Kbps
Kanaal(en) : 6 kanalen
Kanaalposities : Front: L C R, Side: L R, LFE
Stroomgrootte : 319 MiB (9%)
Taal : Engels
Default : Ja
Forced : Nee
Menu
00:00:00.000 : en:Chapter 1
00:08:15.000 : en:Chapter 2
00:19:22.000 : en:Chapter 3
00:28:34.000 : en:Chapter 4
00:37:08.000 : en:Chapter 5
00:46:37.000 : en:Chapter 6
00:56:31.000 : en:Chapter 7
01:06:29.000 : en:Chapter 8
01:16:55.000 : en:Chapter 9
01:28:01.000 : en:Chapter 10
01:38:04.000 : en:Chapter 11
01:48:18.000 : en:Chapter 12 -
They have different dimensions, different frame rates, different audio channels (2 vs. 6) - that's why it's not working. You would need to make those characteristics the same in order to even have a chance of it working.
Shrinking video: is MKV to MKV quicker than MKV to MP4?
By OM2 in forum Video ConversionReplies: 5Last Post: 25th May 2013, 15:51 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
MKV toolNix using AVI demultiplexer to convert VC1
By cal_tony in forum Video ConversionReplies: 5Last Post: 30th Nov 2011, 20:55 -
Problem adding subtitle in MKV
By burple in forum SubtitleReplies: 2Last Post: 7th Nov 2011, 11:34
