May be too easy, but I don't know![]()
I want to input an AAC file and re-encode it into another AAC or M4A.
I can do it by using M4A file, but not AAC.
qaac input.m4a -V73 -o out.m4a
this works
qaac input.aac -V73 -o out.m4a
this not.. something missing. can someone put here the working code?
This is the code i use for encoding to aac/m4a below you can see i've added qaac and neroaac this should help you out
QAAC
ffmpeg -i my-music-file-input.aac -vn -ac 2 -ar 48000 -f wav - | qaac - --threading --normalize --vbr 192 -o my-music-file-output.m4aNERO AAC
ffmpeg -i my-music-file-input.aac -vn -ac 2 -ar 48000 -f wav - | neroaac -ignorelength -lc -br 192000 -if - -of my-music-file-output.m4a -
Thanks.
But can't it be done without using FFMPEG and making a Wav?
I have no knowledge about stdin and stdout.
Can't we use --adts switch with stdin and stdout to do that?
https://github.com/nu774/qaac/wiki/Command-Line-Options
What they say there abt --adts, AAC input or output? -
In 2.55, AAC input tested, worked.
If it fails for you, you can follow stdin wav input method suggested by NiGHT-WiNG with the help of ffmpeg,
or since M4A worked for you, you can quickly mux AAC into M4A and use it. mp4box can be used.
If the audio are taken foema Video, then, extract the track as M4A if you can.Code:mp4box -add input.aac#audio input.m4a qaac input.m4a -V 73 -o out.m4a
Example, here ffmpeg can be used.
No idea what method (stdin or remuxing) gives better quality. I think this remuxing is better and will use less cpu usage. But not sure.Code:ffmpeg -i input.mkv -vn -acodec copy input.m4a qaac input.m4a -V 73 -o out.m4a
But try to fix ur issue with AAC input.
25fps AAC to 23.976fps AAC (slowdown)
By pub in forum AudioReplies: 7Last Post: 22nd Mar 2015, 10:03 -
[AAC] AAC (avcodec), AAC (FDK) or HE-AAC (FDK)
By yopmail in forum AudioReplies: 10Last Post: 3rd Feb 2015, 22:17 -
Whats the difference between AAC (avcodec) and AAC Passthru in Handbrake?
By Nazomon in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2014, 17:49 -
Which audio setting should I selected in XMedia? AAC or AAC (Faac)
By Greg2041 in forum AudioReplies: 3Last Post: 1st May 2013, 08:17 -
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 09:41
