Hi so yes the question is basically that
Can you plz suggest me best resize and sharpen filters for good sharpness and no blocky picture ...
with respect to Downscaling,Upscaling (DVD9) and also reducing/Compressing the file size of 720p/1080p Using x264 Encoder (MEGUI)
i have tried Lanczos and Lanczos 4 but i don't see any difference or is it my eyeswhich cant see the difference??
What Do U All Suggest??![]()
Upscaling - i would give a chance to xxEDIx, for downscaling i would select spline based filters (spline 36 or 64).
http://avisynth.nl/index.php/Resize
http://avisynth.nl/index.php/External_filters#Resizers -
Which resizing filter is best depends on your source. If your source is very sharp you don't want to use a resizing filter that sharpens (Bicubic, Lanczos, SplineXX, etc.) -- it will create over sharpening halos and blocky artifacts will be accentuated. nnedi3 (one of the "xxEDIx" filters pandy mentioned) or nnedi3_rpow2 is pretty good for upscaling but it's much slower than the regular resizing filters.
If you source has blocky artifacts you should us a deblocking filter before resizing. -
For Anime you may consider Waifu2x interesting but it is painfully slow (nnedi3 is significantly faster when compared to waifu).
https://forum.videohelp.com/threads/372157-New-upscaling-algorithm-waifu2x
avisynth: when I resize where is the interlaced flag?
By marcorocchini in forum Newbie / General discussionsReplies: 28Last Post: 24th Sep 2014, 05:55 -
Advice on avisynth filters
By angelroj7 in forum RestorationReplies: 16Last Post: 10th Feb 2014, 15:08 -
DVD PAL to NTSC - Deinterlace, Resize, Filters!!
By Cauptain in forum DVD RippingReplies: 12Last Post: 10th May 2013, 06:36 -
Which filters I should use for this anime? (avisynth)
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2010, 13:32 -
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2010, 08:47
