When I usually do conversion to .mpg I have to extract the audio first and save to .wav with virtualdub as described in the http://www.vcdhelp.com/divxtovcd.htm guide, but I heard that some people can choose the same divx .avi file as their VIDEO and AUDIO source. Is it possible and if it is, how?
Yes, you basicly can do that, just load the same file for both (usually it's being done automaticly), but seperating the audio into a WAV file will in most cases boost up the speed of encoding.
And it also depends on the encoding type of the Audio in the DivX file itself!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Audio/Video multi format/source selector
By YesRushGen in forum DVB / IPTVReplies: 0Last Post: 14th Jan 2011, 19:06 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 14:16 -
How can we check video and audio bitrate for source DVD frmo Amazon?
By Bonie81 in forum DVD RippingReplies: 5Last Post: 21st Apr 2010, 16:14 -
Software that captures audio from video source
By MrIronsides in forum Capturing and VCRReplies: 3Last Post: 11th Mar 2010, 19:42 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11
