Whats the easiest way to rip an audio commentary track from an MP4 video file......![]()
Results 1 to 11 of 11
YAMB can extract it easily. Another method is to remux the file to .mkv with MKVToolnixGUI and use MKVExtractGUI2 to extract the audio.
Just drop the MP4 file to MKVToolnixGUI and click on Start muxing button. After that, load the remuxed MKV file into MKVExtractGUI2, select only the audio (usually the second option) and click on Extract.
apologies for being a lamen, but when I run MKV Extract, it says put into the MKVToolnix Dir. I have done that, but cant find an option to select the open the MkvExtract option.
Use XMedia Recode: https://www.videohelp.com/software/XMedia-Recode . Portable version if you don't want to install it. Drop your mp4 file onto its window. Click on it to mark it, so you can see more tabs with settings. In 'Format' choose format and extension. Check with MediaInfo what audio codec is inside mp4. Usually it's aac. In this case and if your player can play aac, go to 'Audio' tab and in "Mode' choose 'Copy'. If you want to convert audio to a different one like mp3, wav etc choose 'Convert' and set properties of output file like codec, sample rate and channels. in 'Output' on the right click icon 'Bitrate-Calculator' (the bottom one) to do more. Set destination. Click 'Add to queue'. When in 'Queue' tab click 'Encode'.
If you can play whatever audio you have in your mp4 in your player, you can simply demux it with My MP4Box GUI: https://www.videohelp.com/software/My-MP4Box-GUI . 'Demux' tab - Open 'Select file' - Demux. -
Here's a drag and drop solution using this script I just made.
First Download ffmpeg and copy it to the folder where your mp4 video is
then download this attachement, extract the file inside it to the folder where the video and ffmpeg is.
Now simply drag your video into the extracted batch script and when it closes there will be an output file named "Extracted Audio.m4a" Thta's your file.
How do I keep the HD lossless audio track when ripping Blurays?
By TheWalrusKing in forum AudioReplies: 5Last Post: 15th Feb 2015, 00:52 -
ffmpeg: add audio track to a mp4
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2014, 09:28 -
Making an MP4 video with audio track only
By BladePoint in forum EditingReplies: 12Last Post: 4th Feb 2013, 21:29 -
How to import DTS audio track to mp4?
By jagojon3 in forum EditingReplies: 5Last Post: 25th May 2012, 18:51 -
How do I replace audio track on Mp4?
By unwired in forum EditingReplies: 3Last Post: 24th Jul 2011, 14:53
