Hi
someone captured a 720p hdtv video
when there isn't movement the image quality is ok
but when there is movement there is kind of ghosting... how could i play it without this blur?
thanks
	try mediainfoxp to get the specs on the video and post them. --
	General
 Complete name : D:\DownloadS\2012.mkv
 Format : Matroska
 Format version : Version 2
 File size : 1.39 GiB
 Duration : 1h 15mn
 Overall bit rate : 2 651 Kbps
 Movie name : video
 Encoded date : UTC 2014-12-30 11:19:10
 Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
 Writing library : libebml v1.2.3 + libmatroska v1.3.0
 Video
 Format : AVC
 Format profile : High@L4
 Format settings, CABAC : Yes
 Format settings, ReFrames : 3 frames
 Muxing mode : Header stripping
 Codec ID : V_MPEG4/ISO/AVC
 Duration : 1h 15mn
 Bit rate mode : Variable
 Bit rate : 2 214 Kbps
 Maximum bit rate : 25.0 Mbps
 Width : 1 280 pixels
 Height : 720 pixels
 Display aspect ratio : 16:9
 Frame rate mode : Constant
 Frame rate : 24.000 fps
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.100
 Stream size : 1.16 GiB (84%)
 Writing library : x264 core 135 r2345 f0c1c53
 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
 Default : Yes
 Forced : No
 Audio
 Format : AC-3
 Format/Info : Audio Coding 3
 Format settings, Endianness : Big
 Codec ID : A_AC3
 Duration : 1h 15mn
 Bit rate mode : Constant
 Bit rate : 384 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Compression mode : Lossy
 Stream size : 206 MiB (14%)
 Language : Hebrew
 Default : Yes
 Forced : No
 Text
 Format : ASS
 Codec ID : S_TEXT/ASS
 Codec ID/Info : Advanced Sub Station Alpha
 Compression mode : Lossless
 Default : Yes
 Forced : No
	The ghosting is in the captured video. Possibly a blend deinterlace. There's no real fix.
	If you want to upload a short sample of the source (with moderate motion that shows the problem) someone will take a look at it. Problems like this can sometimes be alleviated. But it will require a lot of learning. Last edited by jagabo; 23rd Sep 2015 at 10:16.
  Awful ghostingBy Friggigatto in forum RestorationReplies: 3Last Post: 26th Mar 2014, 08:14
  UncropMKV causes ghostingBy endless45 in forum Video ConversionReplies: 3Last Post: 22nd Mar 2014, 00:15
  Intermittent GhostingBy koberulz in forum RestorationReplies: 1Last Post: 27th Feb 2012, 11:14
  Ghosting after deinterlacing?By spinmonk in forum Video ConversionReplies: 15Last Post: 22nd Jan 2012, 16:44
  Ghosting effectBy nikgelfi in forum Capturing and VCRReplies: 27Last Post: 6th May 2011, 08:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
