Through the years I have recorded a lot of family videos of various things and want to be able to put them on a DVD to be played on a stand alone dvd player so I can make multiple copies and give them to family members to watch. These videos are in formats such as avi, wmv, mov, mpg and so forth. I know they would have to be converted over to some other format but I have no clue on what format. I've searched a lot of websites to only confuse myself even more. I know many years ago I made some using vcs or something like that but the quality was just horrible but watchable.
Any suggestions on how to go about converting my videos and burning them on to a DVD for a stand alone player, what software?
Results 1 to 13 of 13
OK, downloaded and ran AvsToDVD , burned to DVD but only audio was there, no video. Also it said that imgburn was not installed so I DL'd that and installed it.
Also for some reason one of the programs I downloaded and installed also installed some dang malware and I spent an hour getting rid of those.
Now I wonder why there was no video on the DVD? -
You're right, I have no idea what all this means. The DVD plays on my computer fine, just not the stand alone DVD on my TV.
General
Complete name : E:\\VIDEO_TS\VIDEO_TS.IFO
Format : DVD Video
Format profile : Menu
File size : 8.00 KiB
Video
Format : MPEG Video
Format version : Version 1
Bit rate mode : Variable
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Compression mode : Lossy
General
Complete name : E:\\VIDEO_TS\VIDEO_TS.BUP
Format : DVD Video
Video
Format : MPEG Video
Width : 720 pixels
Height : 576 pixels
Standard : PAL
General
Complete name : E:\\VIDEO_TS\VTS_01_0.BUP
Format : DVD Video
Format profile : Program
File size : 58.0 KiB
Duration : 1h 19mn
Overall bit rate : 100 bps
Video
Format : MPEG Video
Format version : Version 2
Duration : 1h 19mn
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Standard : PAL
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 19mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Language : English
Menu
Duration : 1h 19mn
00:00:00.000 : Chapter 1
00:05:00.440 : Chapter 2
00:10:00.280 : Chapter 3
00:15:00.280 : Chapter 4
00:20:00.280 : Chapter 5
00:25:00.280 : Chapter 6
00:30:00.280 : Chapter 7
00:35:00.280 : Chapter 8
00:40:00.280 : Chapter 9
00:45:00.280 : Chapter 10
00:50:00.280 : Chapter 11
00:55:00.280 : Chapter 12
01:00:00.280 : Chapter 13
01:05:00.280 : Chapter 14
01:10:00.280 : Chapter 15
01:15:00.280 : Chapter 16
List (Audio) : 0
General
Complete name : E:\\VIDEO_TS\VTS_01_0.IFO
Format : DVD Video
Duration : 1h 19mn
Video
Format : MPEG Video
Duration : 1h 19mn
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Audio
Format : AC-3
Duration : 1h 19mn
Language : English
Menu
Duration : 1h 19mn
List (Audio) : 0
General
Complete name : E:\\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 18mn 20s
Overall bit rate : 7 806 Kbps
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : N=12
Duration : 18mn 20s
Bit rate : 7 489 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.722
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 978 MiB (96%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 18mn 20s
Bit rate mode : Constant
Bit rate : 192 Kbps
Stream size : 25.2 MiB (2%)
Menu
General
Complete name : E:\\VIDEO_TS\VTS_01_2.VOB
Format : MPEG-PS
Duration : 18mn 20s
Overall bit rate : 7 807 Kbps
Video
Format : MPEG Video
Duration : 18mn 20s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 00:18:20:11
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Delay relative to video : -184ms
Menu
General
Complete name : E:\\VIDEO_TS\VTS_01_3.VOB
Format : MPEG-PS
Duration : 18mn 20s
Video
Format : MPEG Video
Duration : 18mn 19s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 00:36:41:02
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Delay relative to video : -504ms
Menu
General
Complete name : E:\\VIDEO_TS\VTS_01_4.VOB
Format : MPEG-PS
Duration : 18mn 20s
Video
Format : MPEG Video
Duration : 18mn 20s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 00:55:01:06
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Delay relative to video : -376ms
Menu
General
Complete name : E:\\VIDEO_TS\VTS_01_5.VOB
Format : MPEG-PS
File size : 331 MiB
Duration : 5mn 55s
Overall bit rate : 7 805 Kbps
Video
Format : MPEG Video
Duration : 5mn 55s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 01:13:21:10
Stream size : 316 MiB (95%)
Audio
Format : AC-3
Duration : 5mn 55s
Bit rate : 192 Kbps
Delay relative to video : -280ms
Stream size : 8.15 MiB (2%)
Menu -
Will check it. I tried the DVD in another player and it played great and it's about 5 years older than the other one.
I'll make another DVD using those settings and let you know the outcome.
I believe the developer is European so PAL may be the default setting. Just change that to NTSC. The second picture down in Baldrick's guide (and julitomg's explanation) shows where you do it:
https://forum.videohelp.com/threads/353284-AVStoDVD-beginners-guide-Any-video-to-DVD-Video -
OK, I made another DVD using NTSC and now it says "No Disc" in my stand alone player but it still plays on my computer. Here's the text file again but I think I'll take this problem over to the correct thread.
General
Format : DVD Video
Video
Format : MPEG Video
Width : 720 pixels
Height : 480 pixels
Frame rate : 29.970 fps
Standard : NTSC
General
Format : DVD Video
Video
Format : MPEG Video
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
General
Format : DVD Video
Duration : 1h 19mn
Video
Format : MPEG Video
Duration : 1h 19mn
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Audio
Format : AC-3
Duration : 1h 19mn
Language : English
Menu
Duration : 1h 19mn
00:04:59.666 : Chapter 2
00:09:59.666 : Chapter 3
00:14:59.366 : Chapter 4
00:19:59.066 : Chapter 5
00:24:58.766 : Chapter 6
00:29:58.466 : Chapter 7
00:34:58.166 : Chapter 8
00:39:57.866 : Chapter 9
00:44:57.566 : Chapter 10
00:49:57.266 : Chapter 11
00:54:56.966 : Chapter 12
00:59:56.666 : Chapter 13
01:04:56.366 : Chapter 14
01:09:56.066 : Chapter 15
01:14:55.766 : Chapter 16
List (Audio) : 0
General
Format : DVD Video
Duration : 1h 19mn
Video
Format : MPEG Video
Duration : 1h 19mn
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Audio
Format : AC-3
Duration : 1h 19mn
Language : English
Menu
Duration : 1h 19mn
List (Audio) : 0
General
Format : MPEG-PS
Duration : 18mn 20s
Video
Format : MPEG Video
Duration : 18mn 20s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.723
Time code of first frame : 00:00:00;00
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Menu
General
Format : MPEG-PS
Duration : 18mn 20s
Video
Format : MPEG Video
Duration : 18mn 20s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 00:18:20;14
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Delay relative to video : -176ms
Menu
General
Format : MPEG-PS
Duration : 18mn 20s
Video
Format : MPEG Video
Duration : 18mn 19s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 00:36:41;02
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Delay relative to video : -506ms
Menu
General
Format : MPEG-PS
Duration : 18mn 20s
Video
Format : MPEG Video
Duration : 18mn 19s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 00:55:01;08
Audio
Format : AC-3
Duration : 18mn 20s
Bit rate : 192 Kbps
Delay relative to video : -383ms
Menu
General
Format : MPEG-PS
File size : 331 MiB
Duration : 5mn 55s
Overall bit rate : 7 804 Kbps
Video
Format : MPEG Video
Duration : 5mn 55s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Time code of first frame : 01:13:21;12
Audio
Format : AC-3
Duration : 5mn 55s
Bit rate : 192 Kbps
Delay relative to video : -277ms
Menu -
I let the software do everything.
Converting two videos to same format
By ChasVideo in forum Video ConversionReplies: 3Last Post: 7th Mar 2015, 05:48 -
Possible to author DVD format to CD
By tns1 in forum Authoring (DVD)Replies: 13Last Post: 3rd Aug 2014, 17:20 -
What format do you convert your videos to?
By johns0 in forum PollsReplies: 14Last Post: 18th May 2012, 06:57 -
How do I author multiple x264 videos to blu ray without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 12Last Post: 14th Sep 2011, 16:49 -
using tmpgenc author how can i include some 20 videos in the menu?
By sumeshkri in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2010, 03:07
