Back in the mid-1980s, I participated in a school talent show. The school recorded the talent show on a VHS tape and made several VHS copies. I borrowed one of the school's VHS copies, and hired a video store to copy the talent show from the school's VHS tape to a blank VHS tape that I had purchased in a store. The video store created a perfect VHS copy on my VHS tape.
Today, 30 years later, I attempted to copy the talent show from my VHS tape to a blank DVD-R that I had purchased in a store. I used a Sanyo DVD Recorder/VCR Combo (model # FWZV475F). Before I began the copying process, I simply played the VHS tape in one VCR and in the VCR portion of the combo. I just played the tape. No copying was going on. And the tape was played perfectly both times. The video looked very good for a 30-year-old VHS tape, with few flaws.
However, when I began the VCR-to-DVD copying process, or the "dubbing", something weird happened. I was watching the video on the TV as the video was being copied, and there were periodic flashes of light in the video. It was as if there were 10-20 flash cameras going off at the same time. This was happening every 5-10 seconds or so.
After the copying was finished, I played the resulting DVD in my standalone DVD player. The resulting video was the same as the video on the VHS tape, except for the periodic flashes.
So, what's going on here? Did the video store that copied the talent show from the school's VHS tape to my blank VHS tape, add some sort of copy-protection mechanism to my VHS tape? I certainly never authorized the video store to do that.
Please keep in mind that the DVD video of the talent show is still very watchable. The DVD video simply makes it look as if the audience is using a lot of flash photography during the show. I would, however, like to find out *why* this flashing phenomenon occurred. Any help from this forum would be appreciated. Thank you.
sounds like the video store might have added the dreaded macrovision copy protection.
Could also be that your recorder falsely detected macrovision since it's most likely the store wouldn't add protection due to the licensing cost for just a school tape.Try using another vcr to the dvd recorder if it has the inputs for video in.
Yup. Sounds like good ol' M/V or a false positive to me too.
You can try a different VCR, but if the problem still persists then it very likely is M/V or a false positive, and a combo VCR/DvD recorder combo will not help. You need an external solution here, as a pass-through. (And yeah, another VCR for separate playback to hook to your recorder assuming it's got A/V input since you can't "put it in between" the VCR and DvD recorder units of your combo deck.)
-More expensive solution: TBC such as the AV-Tool AVT-8710 Time Base Corrector or DataVideo TBC-1000 (or their similar equivalent labels from other distributors).
-More median solution: Grex.
-Cheaper solution: A "digital video stabilizer", such as on eBay. I can't attest to the quality of these units, but the price is usually agreeable if you want to take a chance.
Wondering if that video store owner that made those copies is still around/alive...I hate VHS. I always did. -
I think I know the actual problem here, but since the OP's last activity on the forum was 8 minutes after starting this thread and this reply is 2 months late it's not likely to help them.
Funai makes the DVD recorder mentioned, sold under the Sanyo, Magnavox, and Toshiba names. They also made (make?) machines branded as Philips.
The problem lies with the AGC used by Funai's TBC. Evidently, it horrendously overreacts when an overly-bright signal is input. The user Mini-Me described this.
The reason the Funai combo is able to play the tape without flashing when not in "dubbing" mode is that the TBC is bypassed. It outputs dirty horizontal line sync straight to the output. When "dubbing" mode is engaged, the passthrough output and the DVD recording both go through the TBC step first, wiggling lines are straightened, and the AGC is encountered.
The two samples attached are each the same video that both demonstrate the flashing. One is just recorded from the passthrough and the other ripped from the recording that the machine made. It really goes nuts at the end when the "fade to black" setting of the camera is engaged.
Proffessional VHS to DVD transfer
By efiste2 in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2015, 18:04 -
VHS to DVD Transfer
By VideoChunkster in forum RestorationReplies: 20Last Post: 18th Jul 2013, 09:37 -
Best DVD Recorder for VHS Transfer? Suggestions Appreciated
By UC2005 in forum DVD & Blu-ray RecordersReplies: 31Last Post: 14th Oct 2012, 21:07 -
Something weird is happening here...
By montreal in forum ComputerReplies: 4Last Post: 21st Dec 2011, 15:23 -
I want to put my VHS stuff on to DVD
By GianRoss in forum Newbie / General discussionsReplies: 23Last Post: 15th Mar 2011, 12:02
