I know how to make subtitles for my iPad, but I want it to look similar to closed captioning, complete with a black text box. I combined the text with the m4v using mp4box, then I went into Quicktime Pro and selected a all black image for a mask. It looks like it doesn't work, no box appears in iTunes at all either, it's just the text.
Is there a way to do this? I don't like the transparent look of the box and I really don't want to spend a whole bunch of money on a Mac just to do closed captions.
Do not think you can do it with burnt in subs unless you create the mask at the same time (then the mask is fixed and potentially looks un-tidy)
With external subs you can configure a player such as vlc to do what you want. (the mask then changes as the subs length changes)
Maybe Quicktime Pro also works like that. But I not not use it. -
Quicktime Pro does do it via Text Track, but there is no option to turn it on or off, it's burned in by default, unless there is something I'm missing.
I thought the text descriptors of "Keyed Text" or "Do Not Display" would help in some way but not quite.
Sony TV shows subtitles in black box
By Vok D in forum SubtitleReplies: 8Last Post: 7th Oct 2014, 11:22 -
Change the Aspect Ratio to remove the black bars (iPad)
By mdk92 in forum Video ConversionReplies: 7Last Post: 1st Apr 2013, 17:09 -
rtf text editor that allows black background & white text
By deadmeow in forum ComputerReplies: 4Last Post: 13th Dec 2012, 16:50 -
Extracting text from .caption file
By dan2004 in forum SubtitleReplies: 3Last Post: 17th Nov 2011, 11:41 -
video quality help!! HD 720 BLACK BOX VEHICLE DVR CAMCORDER
By nellster in forum Newbie / General discussionsReplies: 12Last Post: 14th Mar 2011, 19:12
