I am sure this has been asked before, so my apologies in advance. On one level I think it is a simple question, but at the same time maybe not. My workflow involves encoding elementary .264 streams and .aac streams separately. I then mux them using mp4box. But sometimes, for various reasons, I feel a need to demux the resulting mp4. Is there a method to do this losslessly back to .264 and .aac? ffmpeg? mp4box?
I found the following for MP4Box documentation which makes me think otherwise:
Thanks as always.The input file must have enough random access points in order to be splitted. This may not be the case with some video files where only the very first sample of the video track is a key frame (many 3GP files with H263 video are recorded that way). In order to split such files you will have to use a real video editor and re-encode the content.
Yes you can use ffmpeg, mp4box etc... to demux
It's "lossless" in the sense that decoded image is lossless. But there are stream sequence headers, +/- metadata that are lost when you mux and demux. Normally not a problem for most scenarios, but in strict BD authoring , some strict programs will complain. Basically never put it in a container for strict BD authoring -
Ahh, now I understand. I will definitely make note of that. My mp4 muxes are for Youtube, so I don't worry about keeping them BD compliant. But that is probably an oversight on my part. Which reminds me as an Encore user, I need to look again into purchasing DVD Architect.
Encore and DVDA usually don't care about those things. I'm talking about strict BD authoring
Demux a Dolby Surround 2.0 file into separate streams?
By Xoanon in forum AudioReplies: 27Last Post: 2nd Jul 2021, 08:21 -
How to Demux avi with multiple video streams?
By Chojun in forum Newbie / General discussionsReplies: 34Last Post: 11th Dec 2015, 14:29 -
Mux elementary streams to MP4
By wotdefcuk in forum Video ConversionReplies: 21Last Post: 18th Jan 2013, 14:54 -
x264 GUI specifically for blu-ray compliant elementary streams
By turk690 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Apr 2012, 19:20 -
vc1 elementary to h264 elementary question!
By brucexx in forum Video ConversionReplies: 4Last Post: 15th Jun 2011, 23:00
