hello,
I have laptop of dell i7 4510U CPU @2.00GHZ 2.60GHZ 16GB 64bit , graphic card intel 4400.
i know this graphic card isn't enough for edit video and when I tried use in premiere it took time to render.
I saw other laptop so I don't know if to sell it and buy same computer with graphic card of NVIDIA GeForce 920M (4GB DDR3),
it will make the change?
I really confused![]()
IMO CPU and memory is more important than the GPU since not all programs make use of that in video encoding.
It may help if you gave more details of your encoding workflow. The source format, the destination format. Run length etc. Encoding does take time regardless. -
i use in 5d mark iii so it give me format video of mov. i do short videos like 5-6 minutes of clip but when I use in premiere and put like a short video of 10 seconds it takes 8-10 minutes to render it.
Should a laptop take 10 mins to encode 10 secs of video ?. No
Will another GPU speed that up significantly ?. No
There seems to be another issue here and we do not have sufficient details. Background programs etc. running.
BTW your mov is just the container. Your video could be mpeg2 or avc (h.264). And we still do not know your destination format. Mov then could mean quicktime and that could be the bottle-neck. We just do not know right now. -
maybe because I use in plugins of magicbullet in premiere?
it such a pain all this.. I bought new laptop before a week and I thought it's the right laptop. -
Well any form of filtering will slow down encoding.
Don't know anything about Magic Bullet but it's price tag suggests it is aimed for pros who would have fairly powerful systems.
Sorry. Can not help you more. -
Old computer - can it play full HD if upgrade graphic card?
By Prototype v1.0 in forum ComputerReplies: 6Last Post: 1st Nov 2014, 11:32 -
How to Block HDMI output on graphic card?
By snoledan in forum Capturing and VCRReplies: 19Last Post: 24th Feb 2014, 14:21 -
NewBlueFX for Pinnacle S16 Ultimate needs Graphic Card?
By Rikmar in forum Latest Video NewsReplies: 1Last Post: 27th Dec 2013, 15:25 -
Good Graphic Card with TV Tuner
By ila420 in forum Capturing and VCRReplies: 3Last Post: 17th Aug 2012, 10:13 -
Does Graphic Card Makes any Difference in Video Conversion?
By farzad in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 19:20
