Closed Thread
    Sep 2011
    Croatia
    hello there.
    i have a problem on playing this version of movie Stardust.2007.1080p.HDDVD.x264.DTS-DEFiNiTE
    ,witch is ironically the sharpest version there is,
    i have other version that is encoded with the same codec as this one ,same audio and video codecs but diferent resolution,
    it is Stardust.2007.720p dont know the encoding group.
    I play it on lg tv witch does not play DTS so i encode audio to AC3 and it play just fine on tv.
    can someone help me in finding the reason why one can be played and the other cannot,if you need some other info just post here.
    Sep 2011
    Croatia
    here are mediaifo files on booth movies 2 i cannot play 1 i can play just fine
  3. First one iz level 4.1 which your TV supports. Second video is level 5.1 which your TV probably does not support. Might be to much reference frames (8) for 1920x800 resolution.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just buy the DVD and stop messing with downloaded WAREZ crap.
    http://www.amazon.co.uk/Stardust-DVD-Michelle-Pfeiffer/dp/B000Z2GQZG
    Sep 2011
    Croatia
    ok i will try do mux it to lvl 4.1
    what is good software for it,can i use xvid4psp
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Please don't discuss warez rips.
