What are the impacts of x264 lookahead-threads value regarding the quality?
Is it related to to other things such as VBV, MB-Tree, rc-lookahead.. etc?
I heard that too high number of threads like more than 16 may affect the quality a little bit. right?
Is it same with lookahead-threads?
Or different...
lookahead thread count said to be like threads/6 (or threads/4 as I observed, either it is changed now or depends on other parameters)
Among below 3 examples, which would give the better quality theoretically. Is the difference is too insignificant? or not? (Encoding time is irrelevant)
threads 16, lookahead-threads 4
threads 12, lookahead-threads 3
threads 8, lookahead-threads 2
threads 4, lookahead-threads 1
threads 2, lookahead-threads 1
threads 1, lookahead-threads 1
Threads=1 will give the best result. But I doubt you'll notice any difference at normal playback speed. You might see a difference zooming in and A/B switching between still frames. And even then you might not be able to say which is better without comparing to the original.
But why bother asking when you can just test for yourself?
Cut A Video without losing quality in x264
By kaaviyan in forum EditingReplies: 5Last Post: 27th Jan 2013, 13:06 -
Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?
By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 12:45 -
anyone know of a high quality matrix for x264?
By deadrats in forum Video ConversionReplies: 1Last Post: 6th May 2012, 01:09 -
Best Quality Possible in x264
By Metroidn1f in forum Video ConversionReplies: 16Last Post: 29th Apr 2012, 11:13 -
Can't get good quality x264 encode
By silverwolf0 in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2011, 22:45
