I'm attempting to download the Ken Burns Civil War series from PBS. I was able to download an MP4 of the first episode using Flash Video Downloader following the instructions here:
https://www.youtube.com/watch?v=kfZPH_HGGbg
It isn't high quality, but I can view it.
Now I can't download the remaining episodes. The remaining episodes are broken up.
This is the video I'm currently attempting to download:
http://video.pbs.org/video/2365558007/
I've searched the forum and read some of the threads on downloading. I'm not sure which advice applies to flash video. To be honest, I got lost in some of those threads. I know the problem is on my end as far that goes.
I've tried disabling Flash and checking Developer>Network. I don't see anything there to download.
I'm using Firefox and Windows 7.
Does anyone have any advice? I'm open to formats besides MP4 if necessary. This is for my own use, btw. I don't know if I'll get a chance to watch before they are removed. Thanks for any help.
Results 1 to 14 of 14
I was just able to download the above video. An MP4 for the full video (episodes 2 and 3) finally showed up in the downloader dropdown. I clicked on my above link and got it. Before, I was right clicking on the video and opening in a new window or tab and only seeing multi small files. I'll come back later and try to figure out what exactly I did differently. I might just need to copy and paste the link rather than opening in a new window.
you can use youtube-dl
>>>>Code:youtube-dl -g "http://video.pbs.org/video/2365558007/"
hls >>>> mp4 m3u8 >>>> mp4Code:http://ga.video.cdn.pbs.org/videos/civil-war/ae06c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-hls-2500k.m3u8
so you have the direct link
Code:http://ga.video.cdn.pbs.org/videos/civil-war/ae06c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4
Thanks biezom. It looks like I'll be using Python. I'll have to try it later.
I was able to get all of the episodes using the Flash Video downloader. I had to disable Flash Video and then enable again each time for some reason.
I still want to try youtube-dl and get higher quality. I'll post back after I try it. -
I downloaded youtube-dl.exe and have Python 3.5 installed.
I get this message from the command line.
"youtube-dl is not recognized as an internal or external command, operable program or batch file."
I've tried youtube-dl -help and others.
I am in the same directory where I placed youtube-dl.exe.
Am I missing a file? Any suggestions? Thanks. -
Thanks. I was already running as administrator.
I finally got it to work with this:
I tried it with another video and was able to get it.Code:youtube-dl-2015.09.09.exe -g "http://video.pbs.org/video/2365558007/"
Apparently I'm misunderstanding something obvious. I thought running youtube-dl-2015.09.09.exe as administrator would configure it so I could just use youtube-dl at the command prompt. I'm definitely in the correct directory. I've tried it in different directories including C:\.
I am able to run this and the other video in a browser:
Is there another recommended downloader that would preserve the quality to use at this point to make it more portable? Again, I know I'm missing something obvious.Code:http://ga.video.cdn.pbs.org/videos/civil-war/ae06c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4
Thanks for all the help. -
Code:youtube-dl "http://ga.video.cdn.pbs.org/videos/civil-war/ae06c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4" -o video.mp4
Code:livestreamer "httpstream://http://ga.video.cdn.pbs.org/videos/civil-war/ae06c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4" best -o video.mp4
another way was to download the add-on for firefox called "video downloader professional" (or video download helper, but the latter has crapped out on me recently). You have to enable flash for firefox though, of course.
This code:
... gets the message:Code:youtube-dl-2015.09.09.exe "http://ga.video.cdn.pbs.org/videos/civil-war/ae06 c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw010 23_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4" -o video.mp4
"[generic] 0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-mp4-2500k: Request
ing header
[download] Destination: video.mp4
[download] 27.9% of 2.50GiB at 119.16KiB/s ETA 04:24:32ERROR: content too short
(expected 2684533469 bytes and served 747676168)"
I did get this file:
video.mp4.part
I'm trying livestreamer now.
Be back later. Thanks. -
Thanks, MovingParts. I just noticed your reply. When I use video download helper I get mp4s that are just a few kb and don't play. I've used it before and will try to figure out later what I'm doing wrong. It looks like I can record mpeg while streaming.
I did get it with livestreamer. Thanks, biezom. -
Ah, right I forgot. There are some rare cases, where it can not download the video, but will instead create useless small pieces. I know this from a channel called ZDF, I think those tv channels use something that prevents it. All other TV channels I needed this on worked so far.
I was running from the command prompt when I got the file video.mp4.part.
I didn't really see a progress bar, but could view the progress watching the numbers increasing. It stopped loading and gave the error message: ERROR: content too short (expected 2684533469 bytes and served 747676168)"Code:youtube-dl-2015.09.09.exe "http://ga.video.cdn.pbs.org/videos/civil-war/ae06 c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw010 23_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4" -o video.mp4
I was able to download the files with other code. But I'm still curious about why the above didn't work. I'll come back to it later.
With Video Download Helper I did see the progress bar and got the message that it had completed. That file didn't have ".part" attached. It was small and wouldn't play. I've previously used that software for youtube without any problems.
I was able to get everything I wanted with the suggested livestreamer code:
Thanks for all the comments and assistance.Code:livestreamer "httpstream://http://ga.video.cdn.pbs.org/videos/civil-war/ae06c0c3-2576-4329-a614-84ae883fc8ab/200120/hd-1080p-mezzanine-16x9/0a307fd3_civw01023_stack_remastered_1080p_mezz-16x9-mp4-2500k.mp4" best -o video.mp4
PBS Download
By RustyBob in forum Video Streaming DownloadingReplies: 178Last Post: 25th Nov 2017, 15:20 -
Need help to download this video from PBS plz
By vagnerlove in forum Video Streaming DownloadingReplies: 15Last Post: 4th Jan 2015, 00:12 -
PBS download troubles again
By xtal_01 in forum Video Streaming DownloadingReplies: 4Last Post: 26th Oct 2014, 18:12 -
Can't download from PBS site ....
By xtal_01 in forum Video Streaming DownloadingReplies: 5Last Post: 9th Oct 2014, 22:41 -
How to download a PBS video?
By inspiration100 in forum Video Streaming DownloadingReplies: 20Last Post: 19th Nov 2011, 20:58
