Results 1 to 9 of 9
    Mar 2011
    Oregon, US
    Hi,
    What piece of software can split a video every 60 minutes ? John
  2. mp4box can split videos in MP4 container using -split time_in_seconds . Like mkvmerge, the accuracy of the splits depend on your source video and how close the keyframes are together
    Please don't cross post. I removed your other post.
    Mar 2011
    Oregon, US
    How do you split an avi file into 60 minute segments? John
  5. Copy your .avi (?) source to an empty folder.
    Split it with MKVMergeGUI (Global tab).
    Remux the files with ffmpeg (CMD command)
    for %h in (*.mkv) do ffmpeg -i %h -codec copy %~nh.avi
    Mar 2011
    Oregon, US
    What Global Tab? I can't Find it ! Do I use a previous version?
    Mar 2011
    Oregon, US
    Is there a freeware piece of software that will split a long video mpg file at 6:00 and save the parts? Is it idiotproof?
  8. Do I use a previous version?
    No you're using MKVToolnixGUI - Not MKVMergeGUI. You'll find the Splitting on the output tab.
