  1. Hey guys.
    I want to make alpha video (alpha channel) we know that AFX users using this kind of options to export the logo as alpha channel
    so I want to do that by using Avs , I have ass file and I want to encode as alpha channel/ RGB32
    I tried a lot of things but I didn't get the result that I want !_!
    I used this code to make alpha channel video (Dummy) with ass file
    FFVideoSource("C:\Users\X\Desktop\Python\dra.mkv", colorspace = "RGB32").showalpha().TextSub("Dra.ass")
    I used BlankClip() also , so I encode the dummy video by Lagarith Lossless Codec" with RGB & RGBA mode
    but, when I imported alpha video in AvsPmod the text not appearing when I encode With RBGA Mode, but with RGB Mode
    only alfa_2 video appearing with white background!!
    this my code :
    A = avisource("C:\Users\X\Desktop\New folder (2)\vid.avi")
    V =  avisource("C:\Users\X\Desktop\New folder (2)\alfa_2.avi")
    insertsign(A, V, 0,0 )
    same thing happened with I used (Overlay(A,V, mask =V, mode = "blend" , opacity = 1.0))
    so I want to know, is there something missing, or I did wrong?!
  2. What is "dra.mkv" ?
    If you have an .ass subtitle , that you want to overlay, why don't you just use Textsub() directly on the other video ?
  3. Originally Posted by poisondeathray View Post
    What is "dra.mkv" ?
    actually its just OP song I just imported op video (dra.mkv) to get the resolution etc..
    it's just an option I used BlankClip also
    BlankClip(length = 2109, width = 1280, height = 720, fps = 23.976, pixel_type ="RGB32" )
    actually this just a test, I tried to do something different, because I made Fxs for text by using AVS .
    so I import the FX.avs script to make alpha channel video, to blend alpha video with other one
    but in this case I used text jut for testing, someone told me it will work , but I don't know actually.
  4. Can you describe more clearly what you want to do ? Describe it in plain words, not avisynth
    Did you want the subs on a transparent background ? For use in another program ? Because it would be easier to use TextSub() directly
    The main problem is you are starting with a non transparent video. Blankclip() video is black. Not transparent. When you use showalpha() it will become white (the A is 100% white in an blank video)
    Or am I completely wrong in trying to guess what you want to do ?
  5. this text Fx by using Avs script
    I want to make alpha channel for this Fx to blend it with "X" video like AFX users doing they are exports their works (log or karaoke etc) as alpha channel video
    this my script to import Text Fx
    Import("C:\Users\X\Desktop\Python\movlay.avsi") ### function to make Fx for text by
    Import("C:\Users\X\Desktop\Python\OP_FX.avs")  ## make mask for ass file "Texts"
    V = FFVideoSource("C:\Users\X\Desktop\Python\dra.mkv",colorspace = "RGB32")
    FXMove(V,0)
    as u see I'm trying to encode this Fx with alpha channel that's why I used "Lagarith Lossless Codec" RGB mod
    but when I used AvsPmood it shows that video isn't alpha -_-"
    so I encode this Fx with black dummy video
    Import("C:\Users\X\DesktopPython\OP_FX.avs")
    V= BlankClip(length = 2109, width = 1280, height = 720, fps = 23.976, pixel_type ="RGB32" )
    FXMove(V,0)
    then I used Overlay filter to blend (dummy video & TEXT Fx = alfa_4) with "vide.avi"
    A = avisource("C:\Users\X\Desktop\New folder (2)\vid.avi",pixel_type = "RGB32")
    V =  avisource("C:\Users\X\Desktop\New folder (2)\alfa_4.avi", pixel_type = "RGB32") ##.Levels(0,1.4,255,8,248)
    ## m = insertsign(A, V, 0,0)
    Overlay(A,V, mask =V, mode = "blend" , opacity = 1.0 , output = "RGB32")
    but unfortunately there's a black border around
    it should be like this
  6. It's ok now, I found another method
    Thnax =)
