First, sorry for being off topic but there isn't a hardware forum for sound cards as used in this manner.
I am building a computer that will be connected to my TV and home entertainment sysyem full time so I can watch svcd, vcd, and divx whenever I want. My DVD player (Sony NS400) says it plays vcd, but its fussy and it doesn't play svcd or divx at all. Since I have most of the computer equipment already I figured this would work.
I have a Sony Receiver with Bose AM-10 5.1 speakers. Does the sound card I use make a difference for this application? When people encode in vcd,svcd,divx is the sound encoded for 5.1 playback? Any input about sound card and difference it makes is appreciated.![]()
No standalones yet play divx files. And some wont accept SVCDs. If you are asking about the quality of VCD audio. Its usually cd quality. However, it not Dolby 5.1. To use that you need media that has it, like a commercial DVD. And divx movies, I am assuming you mean the kind you download off things like kazaa. You will find usually the audio isnt all that great. Using 5.1 speakers on a VCD is overkill. Also even if you play DVD in your computer the 5.1 can only be used to its fullest on the speakers if your sound card is dolby 5.1 enabled.
When people encode for VCD they use 224kbps MPEG,stereo.
And divx files vary. Some use 48kbps mp3 encoding, making for very hollow echoing sound. But other use 96-160kbps mp3 which sound good quality.
Really, when it comes to a soundcard, I use the soundblaster 64V and it makes my videos sound awesome on my machine and my sound card is worth all of 15-25 dollars,came with the system. -
Thanks for the reply. It sounds like getting the 5.1 card (which only costs about $75 anyway) isnt really necessary since most if not all (s)vcd, divx are not encoded in 5.1 in the first place. Like you say a $25 sound card will work fine.
THanks for the advice
Help watching tv on Avermedia HD DVR capture card
By mason dixon in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2011, 11:00 -
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 22:38 -
Video Card for LIVE Tv Watching (zero second delay)
By mabus in forum Media Center PC / MediaCentersReplies: 38Last Post: 1st Dec 2009, 12:00 -
no sound no matter what format I convert to from .mov
By chrishawaii in forum ffmpegX general discussionReplies: 1Last Post: 26th Aug 2007, 12:45 -
Watching multiple streams from a single capture card?
By Drunia in forum Newbie / General discussionsReplies: 11Last Post: 4th Jun 2007, 17:26
