Hello! I have a 25 FPS video from which I want to extract audio and sync it to a 23.976 FPS video. I managed to do it fairly easily by converting 23.976 FPS video to 25 FPS with MKVToolnixGUI, copying it to MP4 with FFmpeg and loading it in Sony Vegas. From there, I opened the audio I wanted to sync, used the original one as a reference (I stretched it first in Toolnix by 960/1001) and voilà! I synced it just by moving the audio track and splitting it in one place. I changed the video track because I read the following on MKVToolnix's GitHub: "First of all: don't. If you can avoid it then do not do it. Instead apply the opposite to the video and subtitle tracks present." I asked a guy who has experience with this kind of stuff, he said the opposite; do change the audio track (he recommended Sound Forge) and don't touch the video. Whom should I listen to? I feel like modyfing the audio is a better thing to do because I don't want to re-encode the video, and I feel like MKVToolnix's FPS change option is just a workaround, not a real deal. It does work, but it's just a set of commands inside the container.
Anyway, this isn't why I'm posting this thread. I came across 29.970 FPS video and I need to do the same thing as above; sync an audio file from a 25 FPS video. I again tried MKVToolnixGUI to apply FPS change to 25, but the ending file is five minutes longer and there's no way to do anything with it. 23.976 to 25 FPS conversion shortened the video by 59 seconds, so now I'm wondering how I did sync the audio without stretching it or doing anything besides moving and splitting one time. This shit is confusing.Any tips regarding this? I tried MeGUI with AviSynth script and AssumeFPS, it extended the video just like Toolnix. ConvertFPS kept the original duration, which is nice, but as I said earlier, I don't really want to re-encode the video. Is there any other solution? What should I do to an audio file in order to sync it with 29.970 FPS video?
Thank you in advance!
Results 1 to 12 of 12
That doesn't work when FPS is different. I just tried it and audio gets out of sync very quickly. At the end of the file, it's late a whole lot.
Create an Avisynth script for the audio.
Use TimeStretch() Function
Syntax:
TimeStretch(clip,tempo=(newFPS)/(oldFPS)*100)
pitch and rate also count as parameters if you want to use it.
- tempo deals with speed with no pitch shift
- pitch doesn't deal with speed
- rate deals with speed and pitch
The syntax above is for all and default for any parameter is 100.
Just do some tests with this.Last edited by Shaylen; 18th Sep 2015 at 07:22. Reason: Parameters all have 100 as default
I am sure. It is indeed simple, that's how I synced an audio as I said in the first post (by using a common audio peak as a reference), but this 29.970 FPS video is a whole different story.
@Shaylen Thanks! I will give it a try now. -
I get an error when opening .avs script: "I don't know what 'clip' means".
Code:A = FFAudioSource("C:\Users\GUEST\Desktop\000.mkv") TimeStretch(clip,tempo=(25)/(29.970)*100)
When you tried the control drag function ( not velocity) in Vegas , did you also right click on the audio track after your desired control drag and tick the box "lock audio to stretch".
clip actually stands for a variable that's containing the source. It's in all Avisynth functions.
In this case, 'A' is the containing variable so here's what it should look like:
TimeStretch(A,tempo=(25)/(29.970)*100)
When using frames rates that's not whole numbers use fractions. e.g. 29.970 --> 30/1.001
because it may or may not distort the audio a bit.
Also audio scripts usually contain a BlankClip() for video when piping to an encoder.
If you want to learn more about how these scripts are structured, download RipBot264. It gives you complete access to
the process on how it does it's encodes from input to scripts to encodes to new files. This is partially how I learned how
it works.
These temp files for RipBot264 should be in "C:\\Temp"Last edited by Shaylen; 18th Sep 2015 at 10:54.
I finally succeeded! Thank god. A guy on Doom9 said I needed to do 25 to 23.976 FPS audio conversion instead of 25 to 29.970 FPS (which created a five minutes shorter file), so I did. I stretched the audio for 55 seconds (I used Vegas' Élastique Pro, is that a better method than none?) and voilà!
Thank you, guys, for helping!
GOM & VLC no longer change audio pitch when changing speed...
By PleaseSendHelp in forum Software PlayingReplies: 4Last Post: 11th Jan 2017, 16:22 -
Trouble with audio speed and syncing
By Solowing in forum AudioReplies: 15Last Post: 13th Aug 2014, 23:35 -
Video/audio syncing problem
By copo in forum EditingReplies: 2Last Post: 7th Dec 2013, 19:20 -
Video and Audio Syncing
By pboong in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2013, 09:09 -
Audio syncing problem...
By Huntr777 in forum MacReplies: 3Last Post: 1st Aug 2011, 16:30
