It's all set as interlaced.
There isn't.Third, if everything is really interlaced , there should be --tff flag in x264 command line or marked properly in MeGui settings..
Just found a setting that will put it there, though. No idea how I missed it the first time. Quick encode on a 30-second clip, and MediaInfo no longer says it's progressive. Doesn't say it's interlaced either, though. I'll compile and see how it goes.
Results 31 to 32 of 32
Missed this while typing, and MediaInfo does now say MBAFF under Scan Type so I'm assuming that's good.
I'm assuming that at some point, the video got flagged as progressive, and treated as progressive from then-on. The source is interlaced, as it should be, so it's just a matter of getting that recognised at the relevant steps. Obviously via the MeGUI setting I missed earlier. So we should be sorted. DoStudio seems happy to compile it, so it should be okay compliancy-wise, although I don't know how much it checks for that. I did set Blu-ray as the target playback device in MeGUI.
Adobe premiere pro - correct way of exporting to DVD?
By hasselblad in forum Authoring (DVD)Replies: 4Last Post: 21st Feb 2013, 10:49 -
Exporting from Adobe Premiere Pro not working
By Devilsadvocate in forum EditingReplies: 1Last Post: 29th Mar 2012, 12:04 -
Premiere Pro is exporting audio at -3dB
By Asterra in forum AudioReplies: 6Last Post: 11th Jul 2011, 19:38 -
Exporting HDV with Premiere Pro 2
By HDVth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Mar 2011, 15:41 -
Premiere Pro Cs4 exporting issues
By gooberguy in forum EditingReplies: 8Last Post: 27th Jan 2011, 22:15
