Hi there,
I'm currently working on a command that lets me convert a full DCP to a x264 high 4.1 MKV file. here's what I have:
I detected the crop size using ffplay. the error it now gives is:Code:ffmpeg -i "VIDEO_INPUT.mxf" -i "AUDIO_INPUT.mxf" -map 0:0 -filter:v "crop=1984:1072:8:4" w=1920 h=1038 -c:v:0 libx264 -preset placebo -crf 14 -map 1:0 -c:a:1 copy -c:a:2 ac3 -ab 640k "OUTPUT.mkv"
is there maybe something wrong with the order it's in?Code:[NULL @ 0000000008c80680] Unable to find a suitable output format for 'w=1920' w=1920: Invalid argument
I also want it to be high profile 4.1. I usually do these encodes with HandBrake, but I couldn't find the settings that handBrake uses and how to use those settings in ffmpeg. So if some of you have any tips about that, that would be great.
bye!
Results 1 to 11 of 11
It is not possible to crop to an amount LARGER than your source. If you start with 1920x1080 or 1920x1038, the resulting values have to be <=, yet you have 1984 in there...
Scott -
I start out with a flat video, so 1998x1080, crop it to 1984x1072 and then resize to 1920x1038.
If it doesn't pass the parameter (like -crf in your existing command):
you may have to pass libx264 specific parameters, probably like:Code:-profile high
(according to the recent help output, the first variant should work, but no warranty).Code:-x264opts "profile=high"
Regarding Level 4.1, you should usually not use such a parameter because it won't ensure that encoding limits are used, just that this level is put in the header; instead, use VBV limits matching this desired level to guide the encoder in utilizing the available bitrate range. -
part from one of my scripts (DOS, Win CMD):
andCode:@SET x264opts="bframes=2:bitrate=%vbitrate%:vbv-maxrate=%vbitrate%:vbv-bufsize=%vbuffsiz%:no-scenecut:nal-hrd=cbr:slices=4:tff=1:open-gop=0:colorprim=bt470bg:transfer=bt470bg:colormatrix=bt470bg:fullrange=off:overscan=show:pic-struct:aud:force-cfr:level=4.1:keyint=%gop%:keyint_min=%gop%:qpmin=4:cabac=1:threads=auto:no-psnr:no-ssim:bluray-compat"
feel free to modifyCode:@ffmpeg -i %1 -c:v libx264 -preset veryfast -tune fastdecode -profile:v high -x264opts %x264opts% -x264-params %x264opts% ...
thanx, I now have written this command:
I tried to use the same encoding settings as Handbrake.Code:ffmpeg -i "VIDEO_INPUT.mxf" -i "AUDIO_INPUT.mxf" -map 0:0 –map 1:0 -filter:v "crop=1984:1072:8:4,scale=w=1920:h=1038" -c:v:0 libx264 -preset medium -profile:v high -level 4.1 -crf 17 –maxrate 62.5M –bufsize 78.125M -x264opts keyint=240 -pix_fmt yuv420p -map 1:0 -c:a:0 copy -c:a:1 ac3 -ab 640k –map_metadata -1 "OUTPUT.mkv"
Here's the media info of a video I encoded with Handbrake:
And here is the media-info of a video I encoded with this tool:Code:General Format : Matroska Format version : Version 4 / Version 2 File size : 322 MiB Duration : 1mn 50s Overall bit rate : 24.5 Mbps Writing application : Lavf56.36.100 Writing library : Lavf56.36.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Width : 1 920 pixels Height : 1 036 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 142 r2479 dd79a61 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=14.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Audio #1 ID : 2 Format : PCM Codec ID : A_PCM/INT/LIT Duration : 1mn 50s Bit rate mode : Constant Channel(s) : 6 channels Sampling rate : 48.0 KHz Bit depth : 24 bits Delay relative to video : 3ms Default : No Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1mn 50s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : 11ms Stream size : 8.40 MiB (3%) Default : No Forced : No
As you can see I used different videos, that's probably (hopefully) why I had to use different CRF values. I triend to use the settings from the encoding settings from Handbrake, here are the settings from handbrake and ffmpeg:Code:General Format : Matroska Format version : Version 4 / Version 2 File size : 455 MiB Duration : 2mn 24s Overall bit rate : 26.3 Mbps Writing application : Lavf56.36.100 Writing library : Lavf56.36.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Width : 1 920 pixels Height : 1 038 pixels Display aspect ratio : 1.85:1 Frame rate mode : Variable Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 146 r2538 121396c Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Audio #1 ID : 2 Format : PCM Codec ID : A_PCM/INT/LIT Duration : 2mn 24s Bit rate mode : Constant Channel(s) : 6 channels Sampling rate : 48.0 KHz Bit depth : 24 bits Delay relative to video : 5ms Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 2mn 24s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 32 bits Compression mode : Lossy Stream size : 11.0 MiB (2%) Writing library : Lavc56.41.100 ac3 Default : Yes Forced : No
@pandy:Code:HB: cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=14.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 FF: cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Is this kind of simular to what you suggested? And how do I enable the first script you posted? I don't really know how to do that yet...
I'll try to do the encode the same video with both handbrake and FFmpeg soon for comparison.
Greets! -
My examples are from same script - only because script is more complex and focus on other things than transcode i didn't provided it fully.
After modification those examples may look in Your script like this: [beware - i had no possibility to verify script with your files and also my scripting skills are not good]
You may ask why -x264opts and -x264-params are used for exactly same thing i.e. passing parameters in ffmpeg to xlib264 - from some reason sometimes using only one of them may not work fully as expected - i've learned that passing parameters (same) trough both eliminate sometimes surprises.Code:@SET x264opts="vbv_maxrate=62500:vbv_bufsize=78125:slices=4:open_gop=0:pic_struct=1:aud=1:force_cfr=1:level=4.1:keyint=240:cabac=1:threads=auto:no_psnr=1:no_ssim=1:bluray_compat=1:colorprim=bt709:transfer=bt709:colormatrix=bt709" @ffmpeg -i "VIDEO_INPUT.mxf" -i "AUDIO_INPUT.mxf" -map 0:0 –map 1:0 -filter:v "crop=1984:1072:8:4,scale=w=1920:h=1038:sws_flags=spline:sws_dither=a_dither,format=pix_fmts=yuv420p" -c:v:0 libx264 -preset medium -tune film -profile:v high -crf 17 -x264opts %x264opts% -x264-params %x264opts% -map 1:0 -c:a:0 copy -c:a:1 ac3 -ab 640k –map_metadata -1 "OUTPUT.mkv"
Avidemus 2.6.6: output format mpeg-PS-Muxer, What is "Configure: free" for?
By MovingParts in forum EditingReplies: 1Last Post: 8th Jun 2015, 11:42 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
Why does FFmpeg stop with an error message with "-c copy -b:v 700k"options?
By falco2000 in forum Video ConversionReplies: 5Last Post: 4th Oct 2012, 13:39 -
How to edit "info.dvr" + How to match a particular MPEG format with FFMPEG
By falco2000 in forum Video ConversionReplies: 8Last Post: 27th Sep 2012, 12:00 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52
