Results 1 to 10 of 10
    Dec 2005
    Hey guys, I recorded a video clip on my phone then transferred the video to m,y pc but when I open the video on my pc it is showing upside down, how can I get it to show correctly please? It is mp4.
    Oct 2005
    666th portal
    re-encode it. try vidcoder and put a checkmark in the box to flip vertically.
  3. Drag and drop MP4 file to Avidemux
    from left panel change from Copy to Mpeg4 AVC (x264):
    fromleft Video Output select Filters and add Rotate:
    from left Video Format select MP4 Muxer:
    Select File --> Save
  4. Did you shoot it upside down? Use a player that supports MP4 rotation flags.
    Dec 2005
    Thanks, I am not seeing a way to get to that High Profile window, when i open the Settings I am seeing a Peset "Normal" window, help?
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Are you asking about Vidcoder or AviDemux?
    Dec 2005
    Dec 2005
    I did not purposely shoot it upside down, thinking back now I held my phone above my head to get a better view and I guess that's why it was recorded upside down, next time I will know better, works great with Avidemux, thanks a million for the instructions!
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    in vidcoder click the little down arrow to choose a preset.Click image for larger version
    Dec 2005
    Oh sorry, I got it done with Avidemux but thanks for the instructions too!
