I am looking for a way to soften video some. I usually sharpen and never really need to soften or blur the image, but downscaling my 1080p Blu-Ray to 720p is causing the picture to appear far too sharp.
Are there any good avisynth filters for softening/blurring the video?
Results 1 to 13 of 13
Spline36Resize isn't soft enough? I already tried that over the LanczosResize I usually use.
It helped, but it was so minor that the difference was almost not noticeable even when flipping back and forth through comparison screenshots.
It's also far too sharp when I try to downscale it to 480p.
What would you recommend I try? I wish to soften it some, but I don't wish to lose a lot of fine details from a poor resizer if possible.Last edited by killerteengohan; 15th Sep 2015 at 01:45.
Start with a less sharp resize, like Bilinear(). That's much closer to what the human eye would see when moving the picture farther away. If that's still too sharp (because your source was too sharp) use Blur(0.5) # or whatever value you need.
Here is a visualization for various resizing algorithms.
http://svn.int64.org/viewvc/int64/resamplehq/doc/kernels.html
Notice Spline36 is close to Lanczos3 (Which is LanczosResize(taps=3), or the default LanzosResize() in avisynth) in terms of sharpness and ringing -
I think I will just go with the Blur(0.5) Jagabo mentioned because the source even before being resized was too sharp, the downscale just made it unbearable to the eyes.
Is that about the only blurring/softening filter there is?
Thanks everyone! -
Every denoiser, grainremover etc. does smoothing, but if it is mainly blurring: http://avisynth.nl/index.php/External_filters#BlurringIs that about the only blurring/softening filter there is?users currently on my ignore list: deadrats, Stears555, marcorocchini
GeneralConvolution can be used to blur:
The VariableBlur package includes several blur options including GaussianBlur:Code:GeneralConvolution(matrix="1 1 1 1 4 1 1 1 1")
You can simulate a larger GaussianBlur by calling Blur multiple times.Code:GaussianBlur(0.6)
You can use resize to blur too:
Control the amount of blurring by how small you make the intermediate intermediate. Be careful about width/height restrictions with chroma subsampling.Code:BilinearResize(width*3/4, height*3/4).BilinearResize(width, height)
All those are roughly equivalent to Blur(1.0). And Blur can blur by different amounts vertically and horizontally. For example you can use Blur(0.0, 0.5) to reduce interlace flicker (blur before interlacing).Last edited by jagabo; 19th Sep 2015 at 08:48.
Source video way too sharp, how can I soften/blur it slightly?
By killerteengohan in forum RestorationReplies: 6Last Post: 29th Oct 2014, 17:59 -
AVS video editor's video overlay effect is not good !
By kwanami in forum EditingReplies: 9Last Post: 6th Oct 2014, 21:13 -
Good or Bad idea to merge GoPro video with prosumer camera video ?
By AAC in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 26th Sep 2014, 03:08 -
soften the bright spot on a sme's face in Adobe premiere pro.
By shh1cd in forum EditingReplies: 11Last Post: 15th Feb 2013, 21:04 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41
