I have installed madVR & setup the settings from filters while video is playing to what some guides suggest. I select the renderer in playback-Output under Directshow Video.
And after comparing screenshots of HD video with both, they look identical, maybe minute difference. I was hoping for something significant. Does this sound about right? Maybe I haven't done something right.
thanks
That sounds about right. The benefits are often exaggerated. Especially when you are watching 1080p on a 1080p screen the differences are small. They are bigger if you need to do more scaling.
MadVR does have some other features, though, for example debanding. These can make a bigger difference than the pure scaling.
MPC-HC 32-bit + madVR = frequent crashes in fullscreen
By Ygramul in forum Software PlayingReplies: 7Last Post: 5th Aug 2015, 09:35 -
Problem with MPC + madVR?
By Ryuknar in forum Software PlayingReplies: 4Last Post: 14th Feb 2014, 03:37 -
Possible Portable MPC-HC with Madvr and LavFilters ?
By jslegers in forum Software PlayingReplies: 1Last Post: 21st Oct 2013, 06:55 -
quality of upscaling in vmr 7 vs evr in mpc-hc
By codemaster in forum Software PlayingReplies: 4Last Post: 17th Feb 2013, 09:25 -
MPC-HC+madVR+LAV, how to config display device
By THX-UltraII in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2012, 10:32
