hello,
je cherche un programme qui coupe un morceau d'un vob ou d'un m2ts
enlever le sutdio canal par exemple au début du film etc...
vob tool ne marche bien mais pas pour tous les films
j'en avais un autre pour les m2ts mais une fois l'opération terminée le film était un peu décalé
bref, je cherche un bon prog fiable
merci
Hi,
I am looking for a good cutting soft
I have vob tool for vob but it s not good for every vob
I had another one for m2ts but after operation, the movie had lags
I am looking for a very good and strong software
thanks
Results 1 to 14 of 14
VideoReDo TVSuite
- MPEG2 (mpg, m2v,vob, opens IF0 directly)
- H264/AVC/MTS/M2TS/-AVCHD/MP4/MKV
TMPGEnc Smart Renderer
- MPEG-1
- MPEG-2 Program Stream (.mpg,.m2p,.m2v,.vob)
- MPEG-2 Transport Stream (.mpg,.m2t [HDV, Blu-ray, AVCHD formats)
- MPEG-4 AVC / H.264 (.mp4), MPEG-4 AVC / H.264 Elementary Stream (.264),
- DVD-Video
- DVD-VR, VRO
- Blu-ray (BDAV / BDMV)
- AVCHD (AVCHD 3D left channel data only)
- Microsoft TV recording file (.dvr-ms, .wtv)
- Everio video file (.mod)
- HDV camera (Sony, JVC and Canon models supported)
- FLV (H.264)
- MOV (H.264)
- MKV (.mkv) (MKV support limited to video and audio stream formats normally readable through the MPEG Reader)
- PGMX (.pgmx, .mkv)- My sister Ann's brother -
Hi,
thanks for your links
I tryed VideoRedoTVsuite but not possible to have vob format at the end of the cutting
as I know, vob = mpeg2
but all my videos are .vob and after cutting of part of them, I want to have .vob again..
is it possible? -
WHy do you want vob? Because you can't just replace the vobs later in a DVD.
VOB is a container for MPEG encoded video authored for DVD disc. If you want VOB's, you first edit your MPEG videos and author them to VOB. If you want computer only playback, you don't need to author VOB's. You just use edited MPEG. Smart renering editors like TMPGEnc and VideoReDo are not authoring programs, they're editors and remuxers. TMPGenc Editor has an authoring feature, but you're wasting your time if all you want is PC instead of authored DVD disc.
VOB is useless outside of DvD playback. In fact, it could be problematic if residual metadata-like DvD info that may still be present in the container (such as segmentation), which is why you can't just rename the suffix from .vob to .mpg. You need to properly re-mux (which is done by apps, such as those mentioned here).
Heard somewhere that you can actually mux H.264 into VOB. Yes, even more useless, but can make great conversation at parties.
I hate VHS. I always did. -
edit: issue is resolved
but now, I tryed VideoRedoTVSuite, but I don't like it, it's to complicate and I didn't succeeded to cut my m2ts file.
about TMPG, I cannot open it. I just don't find the right file on the folder.
Is there any other soft for editing m2ts? but something easy to use (I would like to keep my m2ts file, no compression after editing)
thanks -
Let's make sure we're on the same page. We're talking about TMPGenc Smart Renderer to cut and reconstruct vob and mts files, correct? Sounds like you didn't install it correctly if there's no exe.
Hi,
thanks for your new link
I had the wrong soft before
but.. it says ''a watermark appears on encoded pictures on this trial version''
anyway, the software seems to be very complicated to use
I found this one
https://www.videohelp.com/software/Smart-Cutter-Ps-Ts
it looks more easy to handle
do you know it?Last edited by erzane; 25th Sep 2015 at 03:59.
Cutting a m2ts precisely without quality loss?
By takearushfan in forum EditingReplies: 3Last Post: 25th Jan 2013, 00:19 -
Cutting AVCHD/m2ts Files with Avidemux
By glenpinn in forum EditingReplies: 26Last Post: 9th Dec 2012, 09:53 -
Can I go from M2ts to M2ts & just decrease the resolution
By jbitakis in forum Video ConversionReplies: 44Last Post: 9th Dec 2012, 08:59 -
Frame accurate cutting on m2ts files?
By stryker412 in forum EditingReplies: 3Last Post: 29th Jan 2012, 04:20 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 07:34
