I had some earlier trouble with this program but mostly due to being a newbie to this whole vdc world (bought a dvd player a week ago). I now have TmpgEnc encoding to mpeg but part 1 of 2 of a movie is going to take over 8 hours .....
Is this normal ?? I am assuming, as well as hoping to He** that I have a setting wrong ... this seems like a lot of time for the conversion ....
Any help is appreciated ... :-?
Have a great night !!!
Otter
go into:
options - environmental settings - CPU
..and make sure that you have enabled all available from: MMX, MMX-2 , SSE, SSE-2, 3D-Now...
once you've already done so, fastest single thing you can do to speed up processing is faster CPU... -
In TMPGEnc go to settings> motion precision search>set to "motion
estimation search". -
Need a little more info otter. What are your system specs and how long is the movie you're encoding?
Is there anyway to make it all available? becaue I can only select MMX, should I select 'Use Multi-thread' also?....Originally Posted by invisibler
I have a slow comp as well....for me a 20 minute episode takes about 6 hours to convert.... -
if you can only enable MMX and not MMX-2 or the others, then I assume you have a pentium II processor which is 450mhz or less...if this is the case, then it will simply take quite awhile for you to do your encoding...
only enable "'Use Multi-thread" if your computer has multiple processors which I assume it doesn't...if my assumption about your processor is correct, then your option for speeding up encoding is simply to upgrade to a faster processor...
as Bullworth asked, what are your system specs? -
Being a newbie, this may sound stupid but I don't know how to tell how long the movie is
As for the system specs ... I have 320mb ram on an AMD 350 processor .... I am guessing that maybe this is getting just toooo old now ??
Thank you to all who posted replies to my question. If you have any other ideas, I am always listening ....
Have a great day ...
Otter
you could also try under Option-->task priority
that should speed the process up some
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 14:24 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
