  1. I'm archiving VHS tapes to digital discs. To reduce number of discs, Bluray is best option. I read that 11 hours of MPEG-2 SD video can fit onto a 25GB Bluray disc, so I assume AVCHD can fit twice that amount with comparable quality. Am I right?
  2. Member DB83's Avatar
    Jul 2007
    Size is all about bitrate.
    Your example of 11 hours Mpeg-2 would be at a bitrate of 4000 kbps. You should actually get atleast 12 hours.
    But to double the storage you are reducing the bitrate to 2000 kbps (if my maths is correct). Can a BD player actually handle that ?
    So, actually, to maintain a decent visual quality you half the run time. Not double it.
  3. but AVCHD is H.264 which can achieve comparable quality to MPEG-2 at half the bitrate.
  4. Member DB83's Avatar
    Jul 2007
    Hence my rider as to whether it will play.
  5. Member Cornucopia's Avatar
    Well, I'm just spitballing here, but if you had a standard SD DVD at great quality, it would likely have ~8Mbps video bitrate in Mpeg2 format. But you could maybe get by in so-so quality at half that (4mbps), or poorer quality at a third/quarter of that (2-2.5mbps). Assuming full D1 resolution.
    Extrapolating to AVC, which ought to be roughly twice as efficient, you would have 4, 2, and 1-1.25mbps for comparable quality.
  6. I'm a Super Moderator johns0's Avatar
    canada
    I've put on over 20 hours of sd mkv(h.264)on a blu-ray disk as data and on another as authorized blu-ray with no issues with a 4 year old sony as the bd player.
