I used the panasonic thing to convert my avi divx's to mpg. but then when i try to burn that using vcdeasy after it scans the file..it tells me that the resolution is not fit for vcd and it does burn.
Did you use the Standalone or Plugin ? if you used the plugin, which shell did you use ? DVDx / Flask / other ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
