I'm trying to sync up TV DVD audio commentary with a better quality MKV (h.264) video file. The problem is the cuts where commercials would normally be (black frames in the videos) are not the same length in time between to two sources.
In the past I have chopped the AC3 file around scenes, added blank frames to match the commercials breaks (the second or two of black frames) and remerge the AC3 file without re-encoding. But I'm running into a lot of commentaries that are talking through the “commercials breaks” so I need to make the video match the audio file instead of the other way around or else I butcher the audio commentaries.
So is it possible to add and or remove black frames in a MKV (h.264) file without re-rencoding?
Another possibility at least theoretically, you should also be able to to what I need through timecode files, It would basically make the video VFR. I do not care how I get the job done as as long as I can get the job done without having to re-code and lost quality.
Can anyone help?
Making black frames that matches your sources video exactly so you don't have to reconvert wont be simple.
Or find an advanced/nle editor with smart rendering(so it only reconverts the new black frames) and that supports mkv(or maybe mp4 or just h264 video if you remux/demux it to it first using mkv2mp4 or mkvextract ) and ac3. Maybe aviutl or moviestudio or videostudio pro.
How can I remove i-frames from a MPEG-4 file?
By Sorbee in forum Video ConversionReplies: 12Last Post: 2nd Nov 2021, 02:09 -
Remove sub from mkv file
By m4u_hoahoctro in forum SubtitleReplies: 1Last Post: 18th May 2015, 02:40 -
add black bars to MKV
By jeprox in forum Video ConversionReplies: 2Last Post: 6th Jan 2015, 12:23 -
How to add subtitles permanently to existing mp4 h.264 file???
By Patrick_H in forum SubtitleReplies: 20Last Post: 7th Aug 2014, 07:35 -
Can I remove elements from an MKV file?
By elcoyoteloco in forum Video ConversionReplies: 4Last Post: 31st Jan 2011, 09:15
