Results 1 to 1 of 1
    Jul 2015
    Polska
    I am trying to make Bluray disc without extra encoding (both files are Bluray compilant), but I am encountering these problems.
    [19:41:32] Checking for available space and drive types (FAT32/NTFS)...
    [19:41:33] Destination [J:]: NTFS, 4761674.73 MiB (4650.073 GiB) free space
    [19:41:33] Temp folder [J:]: NTFS, 4761674.73 MiB (4650.073 GiB) free space
    [19:41:33] Log started for multiAVCHD v4.1 (build 771)
    [19:41:33] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
    [19:41:33] Processing 2 titles...
    [19:41:33] Existing J:\Bluray\AVCHD\ cannot be used as destination folder!
    [19:41:33] Output will be written to: J:\Bluray\AVCHD-20150910-194133
    [19:41:33] Processing (J:\Sequence 01.ts)...
    [19:41:33] Detected frame reference count: 4 (max:4).
    [19:41:33] Detected video: ID#4113:V_MPEG4/ISO/AVC 1920x1080, fps=23.976, ref=4
    [19:41:33] Total of 1 tracks found in this file.
    [19:41:33] No audio tracks found!
    [19:41:33] Creating clip and playlist info (tsMuxeR)...
            tsMuxeR () output:
    Network Optix tsMuxeR.  Version 2.6.12. www.networkoptix.com
    Decoding H264 stream (track 1): Profile: High@4.1  Resolution: 1920:1080p  Frame rate: 23.976
    Processed 361 video frames
    Flushing write buffer
    Creating Blu-ray stream info and seek index
    Creating Blu-ray playlist
    Mux successful complete
    Muxing time: 0 sec
            tsMuxeR meta:
    MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr  --custom-chapters=00:00:00.000  --vbv-len=500
    V_MPEG4/ISO/AVC, "J:\Sequence 01.ts", insertSEI, contSPS, track=4113, fps=23.976
    [19:41:34] Media transfer: 00000 -> 00000.m2ts
    [19:41:34] Processing playlist...
    [19:41:34] Title #1 added: "Disclaimer"
    [19:41:34] Verifying title...
    [19:41:35] Title has: 0 audio tracks and 0 subtitle tracks
    [19:41:35] Processing (J:\Projekty\Spaleni sloncem\FINAL (1) (1).mkv)...
    [19:41:35] Detected frame reference count: 4 (max:4).
    [19:41:35] Detected video: ID#1:V_MPEG4/ISO/AVC 1920x1080, fps=25.000, ref=4
    [19:41:35] Detected subtitles: ID#4:S_TEXT/UTF8 Language: eng
    [19:41:35] Detected subtitles: ID#5:S_TEXT/UTF8 Language: spa
    [19:41:35] Detected subtitles: ID#6:S_TEXT/UTF8 Language: rus
    [19:41:35] Detected audio: ID#2:A_AC3 (48000Hz 6ch 384kbps) Language: rus
    [19:41:35] Added audio: A_AC3, "J:\Projekty\Spaleni sloncem\FINAL (1) (1).mkv", track=2, lang=rus, timeshift=0ms
    [19:41:35] Extracting SRT/SSA/VOBSUB subtitle tracks.
    [19:41:35] Plase wait - it may take a while!
    [19:43:32] Converting to SRT/PGS...
    [19:43:32] Converting TEXT subtitles to PGS/SUP...
    [19:43:32] [final (1) (1).extr.004.eng.srt]
    [19:43:32] Processing may take some time, so be patient!
    [19:43:32] Advanced subtitle processing (step 1)...
    [19:43:32] Fast mode enabled (1696x284 @ 25.000 fps with 112px margins)...
    [19:45:06] Advanced subtitle processing (step 2)...
    [19:45:07] *** 0 problems of all 0 are fixed!
    [19:45:07] !!! Subtitles may be incomplete!
    [19:45:07] !!! Error converting subtitles! (java?)
    [19:45:07] Adding external subtitles (FINAL (1) (1).extr.004.eng.srt) (eng)
    [19:45:07] Converting TEXT subtitles to PGS/SUP...
    [19:45:07] [final (1) (1).extr.005.spa.srt]
    [19:45:07] Processing may take some time, so be patient!
    [19:45:07] Advanced subtitle processing (step 1)...
    [19:45:07] Fast mode enabled (1696x284 @ 25.000 fps with 112px margins)...
    [19:46:40] Advanced subtitle processing (step 2)...
    [19:46:40] *** 0 problems of all 0 are fixed!
    [19:46:40] !!! Subtitles may be incomplete!
    [19:46:40] !!! Error converting subtitles! (java?)
    [19:46:40] Adding external subtitles (FINAL (1) (1).extr.005.spa.srt) (spa)
    [19:46:40] Converting TEXT subtitles to PGS/SUP...
    [19:46:40] [final (1) (1).extr.006.rus.srt]
    [19:46:40] Processing may take some time, so be patient!
    [19:46:40] Advanced subtitle processing (step 1)...
    [19:46:40] Fast mode enabled (1696x284 @ 25.000 fps with 112px margins)...
    [19:48:15] Advanced subtitle processing (step 2)...
    [19:48:15] *** 0 problems of all 0 are fixed!
    [19:48:15] !!! Subtitles may be incomplete!
    [19:48:15] !!! Error converting subtitles! (java?)
    [19:48:15] Adding external subtitles (FINAL (1) (1).extr.006.rus.srt) (rus)
    [19:48:15] M2TS stream split set at 0MiB...
    [19:48:15] Creating clip and playlist info (tsMuxeR)...
            tsMuxeR () output:
    [19:48:16] tsMuxeR failed to process [J:\Projekty\Spaleni sloncem\FINAL (1) (1).mkv]...
    [19:48:16] Preparing authoring information...
    [19:48:16] Preparing menu pages...
    [19:48:16] Setting main menu for 1 titles...
    [19:48:16] Playback will start with title #1 (Disclaimer).
    [19:48:16] Setting menu properties...
    [19:48:16] Selected TV system: [PAL]
    [19:48:16] Processing clip (CPI/CLPI) files...
    [19:48:16] Completed.
    [19:48:16] Setting Blu-ray format...
    [19:48:16] Done!
    [19:48:16] Saving multiAVCHD quick-load project (mpf):
    [19:48:17] J:\Bluray\AVCHD-20150910-194133\multiAVCHD.mpf (OK!)
            Compilation summary:
            Format: Blu-ray player (BD-R/BD-RE disc)
            1. Disclaimer                               [00:00:14]
            Overall duration : 00:00:14
            Output size      : 38 MiB (0.037 GiB)
    [19:48:17] 1 input file(s) not added!
    [19:48:17] J:\Bluray\AVCHD-20150910-194133 folder created (AVCHD/Blu-ray output)!
    [19:48:17] Burn its CONTENTS to BD-R/RE UDF 2.50/2.60 disc!
    [19:48:18] You may now remove temp folder (J:\tempo\multiTEMP-20150910\).
    [19:48:18] Your compilation contains 0hrs 0min 14sec of video material.
    [19:48:18] multiAVCHD finished in 405.344 seconds (00:06:45.344)!
    [19:48:18] End of log.
    [19:48:18] Cleaning up...
    [19:48:18] Done!
    [19:48:18] For technical support, bug reports and questions:
    [19:48:18] http://multiFORUM.deanBG.com/
    [19:48:18] http://multiAVCHD.deanBG.com/
    [19:48:18] http://multiAVCHD.deanBG.com/doom9/
    [19:48:18] For latest download links and tools visit:
    [19:48:18] http://multiFORUM.deanBG.com/downloads/
