Hello, I'm having trouble with bookmarking time-stamps within a video. As you may know when you press N within a video it memorizes that location, and then when you press B it shows all the time-stamps you've bookmarked.
Now this used to work fine for me. But now even though it works temporarily, once I close the video all these time-stamps are lost.
Can anyone advise?
Thanks!
Dan
Could be just me but... I tried the N and B thing while watching a video in Potplayer but they didn't work... So I tried it with a hex editor, nope no go there either. VirtualDub... Nope.
bookmarking time-stamps within a video.How within a video? What it?it memorizes that location
Sounds like a nice feature but I must have missed something... -
Not sure what Potplayer and VirtualDub have to do with this. Unless they're the same company? Otherwise I wouldn't expect what works in one player to work in another.
While watching a video in GOM press N. Then press B.
When you press B you should get a pop-up saying: Create Bookmark, Clear All Bookmarks, and a few other options.
Now before you press N you should just see the default when you press B. After you press N, when you press B it should show a timestamp as to where in the video you bookmarked.
This much should happen for everyone. I dont have an issue up to this point. My problem is when I close the video I'm losing those bookmark timestamps. -
Did you by chance forget to mention it was gom in your original post? Makes it much easier to check out now at least for me. Maybe I should have known but do not use gom much because .ass subtitles stll not all functional.
Let me check a couple versions.
Thanks -
Oh I'm sorry I thought everything on this forum was about GOM Player. I see now that GOM's nowhere in the url.
Anyway I figured out the problem yesterday. I updated the version and that fixed it, along with a few other issues it had. Man I wish I'd done this 6 months ago, so simple!
Problems with the timestamps of the subtitle
By Petero12 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2015, 06:44 -
MakeMKV not working at all anymore. Need help!
By nateo200 in forum Blu-ray RippingReplies: 18Last Post: 30th Sep 2014, 22:16 -
Timestamps are 23 hours off
By ranbo in forum Capturing and VCRReplies: 3Last Post: 6th Jun 2014, 17:53 -
Audio Bookmarking
By audioamateur in forum AudioReplies: 3Last Post: 24th Nov 2013, 05:26 -
Windows Movie Maker and Windv not working anymore.
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Oct 2010, 20:13
