I've had AnyDVD (Free updates until: Forever) for quite a few years. Never had DVD's other than region 1.
There are a few DVD's I want to purchase that are region 2 (from UK) documentry type stuff from PBS. PBS site (dot.org usa) doesnt sell them. Amazon does.
My question is: With AnyDVD, does the cd/dvd rom 'see' the disk as region 2 & do the thing with 'changing region you can change it 5 times <- however its worded- then its locked into that last region'"
Or, is it region free as far as the cd/dvdrom - computer sees it?
Does this make sense?
(I wasnt sure to start this thread, software, dvd burning, computers. Picked here)
-c-
Yes, no, maybe, I don't know, Can you repeat the question?
If it works like DVDFab, the drive sends Region 2 but the player software sees it as Region Free. No alteration to change numbers takes place.
@hech54
Playback to a PC will not worry a NTSC tv
Of course, we Europeans are lucky in that respect since our PAL tvs can play NTSC disks if the player supports the region. -
Rip to iso, have Argosy, WD 303D, & Dune media players, hopefully, one of em will play it. Otherwise, I'll have to buy a region free dvd player.
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
Depends on the player. A decent region free player will perform the conversion.
Google is your Friend -
Don't confuse "multi-standards" player with "region-free". (unless your idea of a "decent region-free" player = multi-standards player, @KrispyKritter)
As DB83 said, unless you have "MS"-type, "RF"-type will still get you stuck if you live in NorthAmerica and you've got a PAL disc.
Scott -
Remember the good old days of the simple N/P button on the remote. We were so young then. Now we don't need to pull our hair out trying to find a solution to the NTSC/PAL problem....our hair is now falling out on it's own.
Unsure how it works. Any DVD, AnyDVD HD
By SyncroScales in forum DVD RippingReplies: 21Last Post: 7th Jun 2022, 16:19 -
DVDShrink + AnyDVD issue with 'All DVD's'
By cornemuse in forum DVD RippingReplies: 27Last Post: 19th Sep 2017, 09:43 -
DVD ripped using handbrake/anydvd won't play
By Noquestionisdumbright in forum DVD RippingReplies: 24Last Post: 7th Aug 2015, 15:39 -
AnyDVD and AnyDVD HD 7.5.9.0 (Final) not able to work with Interstaller.
By durl in forum Blu-ray RippingReplies: 4Last Post: 7th May 2015, 05:22 -
Using AnyDVD to rip NTSC (R1) DVD using an (R4) DVD drive.
By Speeny in forum DVD RippingReplies: 10Last Post: 25th Nov 2014, 07:01
