  1. I have a custom DVD (Txt2Sup, Subtitle Creator (Wizard), PgcEdit, DvdSubEdit programs used )and want to extract the subs at sub/idx format but can't do it.I tried vobsub configure and vsripper.What do you recommend me? TIA.
    What happens with dvdsubedit and vsrip?
    Maybe dvd captions. Try extract with ccextractor from the vobs.
  3. How to extract them (sub/idx) with dvdsubedit? Vsrip dont work.
    Also how to use CCExtractor ?There is no vobsub on the output.
  4. This is CCExtractor tutorials: http://www.ccextractor.org/using-ccextractor/dvd-cc-extraction.html
    But first check if you have option to extract subtitles
    drag and drop biggest VOB file to Mediainfo:
    If you see RLE text stream its sub/idx
    EIA-608 its closed captions(CC) subtitles
    CCExtractor can extract only closed captions subtitles
  5. Thaks guys.
    It's RLE.What should I do now?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Why wont vsrip work? Program wont start/ crashes or some other error?
    I don't think dvdsubedit can extract to sub/idx. Only srt.
  7. Vsrip 1.0 version supposed to work, as Baldrick said what error you have?
  8. Thanks for helps guys.
    When I select "PGC1" my folder shows empty.
    And now I select "PGC2" and everything is ok . Subs extracted.
