Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Hi all,
    Pretty new in editing DVD's but here goes.
    I have a DVD here (custom made and no access to project files) with several menu's and around 50 clips.
    But after every clip has played it jumps back to main menu and i need to select next clip. This is pretty annoying and i would like to have it play continuously untill all clips are played.
    I tried to remove/edit things with ifoedit and pgcedit without luck.
    Is it even possible to have seamless plaback after every clip and only jump back to main menu after last clip?
  2. Member DB83's Avatar
    Jul 2007
    Theoretically, it is not impossible to edit the ifo file and alter the exit commands to create a seamless playback of all clips.
    But stand back and ask if you really want to do that - it is not a 5 minute job - and having done that you would not be able to select individual clips.
    Better to rip the dvd, extract the clips from a single mpg (if the dvd is actually 50 vobs then that process would be even easier) and re-author a dvd with both options for single play-back and a 'play all' option.
  3. Member Cornucopia's Avatar
