Have you ever noticed this nero problem?
The size of nero (s)vcd disks is incorrect.
You can check this in windows explorer. A disk that contains 700MB+ is just ~1-2MB!
I have burned some vcds' by nero and all of them have this problem.
this just happens in nero vcds', when I burn the file by other burning softwares there is not such an issue!
The problem is the size which is written on the disk, it plays smoothly but I don't know what causes this...
Burn a vcd by nero and check it out in windows explorer. Then burn the same MPEG by another burning software like VideoPack, WinOnCD, NTI, etc and see the size that explorer shows for the disk properties, you will find out what I mean.
please let me know your idea about this.
Hi,
i´ve got the same problem with WinOnCD 5.0. i´ve meand, the problem is another one. Look at my topic "DVD+RW to SVCD". Maybe it happens cause the packsize.
I had something tested with no result.
Bye
Wendel -
You might find that a VCD has two "data" areas on it...one for the filesystem and one for the actual data itself ( the video ). Windows will report the size of the first data area....which is only a meg or two.
Originally Posted by bartman
If so why does windows report the actual size of original vcds and the ones burned by other burning sogtware(which is around the dat file size). Nero does lead in first and after writing the track burns lead out, but I noticed for example WinOnCD writes lead in and lead out after the track and the size of its vcds are shown correctly.
It seems that this problem is not important for anybody here. I have another post about this here
http://forum.vcdhelp.com/viewtopic.php?t=90098&highlight=
but no response.
I need an answer to know if there is a solution to make nero burn vcds correctly. -
Originally Posted by Pied-Piper
The VCD burning program will always burn the filesystem first as it resides on track 1. This has nothing to do with it.
I answered your question here: http://forum.vcdhelp.com/viewtopic.php?p=244477#244477
Regards.Michael Tam
w: Morsels of Evidence
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 21:40 -
video Size for VCD and DVD
By newbievideohelp in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 02:28 -
video size VCD
By Nicksummer in forum VCDEasy GeneralReplies: 3Last Post: 3rd Jun 2008, 08:09 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 10:54
