I have nero and winoncd. I'm trying to make a menu that plays as a 10 second clip and then stops on a picture and displays all the chapters. I've done just a basic menu before, but I'm trying to add some dazzle to my vcd. If it's possible please let me know and what steps to take.
Thanks, for helping a new guy.
Willie!
This sounds easily accomplishable with winoncd 3.8 as long as you use the extended video editor (Keep in mind you may not have this option my first copy didn't) and it's pretty easy from there, also you could try videopak 4 which may have came with your copy of winoncd, this program is very similar to the extended editor and it creates .cpj files just like winoncd so you should be able to burn with winoncd. If you don't have the extended editor or videopak email me and we might be able to figure something out.
If you are willing to dabble with VCDImager, what you ask is simple...
Regards.
Michael Tam
w: Morsels of Evidence
multiavchd menu question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 13:12 -
Pinnacle 12 DVD Menu question
By thejigsawman in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2011, 13:39 -
Menu Question
By coloradoguy in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2009, 02:04 -
newbie dvd menu question
By mikeoliver1313 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2008, 06:05 -
DVDlab menu question
By rizay in forum Authoring (DVD)Replies: 3Last Post: 12th Dec 2007, 09:54
