Hi, but I'm a cat
Please I wonder if virtualdub 64 bit can use a 64bit-directshow codec installed in windows (64bit version) to encode a video file?
thanks
Yes, the 64-bit version of Virtualdub should be able to use the 64-bit Directshow codec. It did the last time I tested it a couple of years ago anyway.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I missed the "encode" part, I thought he was talking about decoder...
Lossless (10 Bit RGB 444) and (10 Bit YUV 422) Compression Codec's
By JasonCA in forum Video ConversionReplies: 62Last Post: 25th Dec 2014, 23:40 -
32/64 bit DirectShow filter
By khodam in forum ProgrammingReplies: 4Last Post: 20th Dec 2013, 12:00 -
virtualdub: input video distorted on 32 bit but not 64 bit
By iggogg in forum EditingReplies: 18Last Post: 5th Oct 2011, 01:34 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
Directshow filter for the Animation codec
By roflwaffle in forum Video ConversionReplies: 8Last Post: 12th Oct 2010, 15:09
