Hi.
When Exact Audio Copy (EAC) compresses files, does it rip into Wav and then convert files?
I converted a Wav file into FLAC and was wondering about Ogg (I haven't done ogg yet).
If I rip from a CD will it be into a wav file first, then I compress it into the other formats? What about other converters/rippers/compressors?
Is there a reason to even think I can rip directly from a CD into formats other than WMA, AAC, MP3 or Wav? Do all the rippers rip into Wav or maybe AIFF first? Then convert?
Thanks.
Yes and yes.
Source is PCM so PCM data need to be buffered anyway and somehow before compression (even online).
And wav is container but i assume PCM data can be in raw and there is no need for any container use (as CD format is well defined). -
Thanks pandy.
If I were using a Mac, iTunes or another program, maybe Linux or Unix(?) would it convert into Wav or Aiff/ALAC?
I have my CD's ripped into Wav already, would there be a difference between using a converter/compression to turn the Wav/PCM into Ogg or FLAC (or other format) compared to ripping from a CD and letting the program turn the files into Ogg or FLAC? It seems there is none. The only difference is I now have to do metadata for the other format.
Is the difference just the quality of programming, coding of the converter/compressor?
Eg: Using Windows Media Player 11 or 12 will rip into mp3 and windows media lossless (or lossy). First PCM is ripped then the file is compressed/encoded. No difference from me ripping Wav/PCM and then converting myself? -
AFAIR EAC can be configured to support any external encoder and as such CD can be converted to any format.
AFAIK wav is capable to carry various data (metadata) side to audio samples. Good converter (wav to xxx) shall be able to use those metadata so i believe from user perspective results should be similar.
Well... this is difficult question as this is comparison between particular applications functionality.
AFAIK EAC and similar software use well known codec implementations (trough libraries) - some application may use similar approach or they may use custom, closed, proprietary solutions (so compression quality may be different).
With current processing power seem any popular format can be compressed in realtime or faster so offline compression is not required.
Exact Audio Copy won't detect my DVD writer
By curlyween in forum AudioReplies: 5Last Post: 8th Jan 2014, 21:10 -
DVD Ripping with scratch tolerance - like Exact Audio Copy
By feelart in forum DVD RippingReplies: 6Last Post: 28th Oct 2012, 12:50 -
?!! Exact Audio Copy vs. dBpoweramp !!?
By flashandpan007 in forum AudioReplies: 12Last Post: 1st Jun 2011, 15:21 -
!!! Exact Audio Copy 99,99% enough? Parameters OK?
By flashandpan007 in forum AudioReplies: 14Last Post: 13th Feb 2011, 08:51 -
Exact audio copy refuse to extract to Mp3 now
By Blå_Mocka in forum AudioReplies: 8Last Post: 14th Nov 2010, 04:19
