I have a DVD with one menu and four Titles. None of the titles have subtitle in it.
There are eighteen files in it.
Menu Structure:
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
Each Title have the following structure:
VTS_0x_0.BUP
VTS_0x_0.IFO
VTS_0x_1.VOB
here x=1,2,3,4,5
Each VOB files have the following properties in common.
Width: 352 pixels
Height: 240 pixels
Frame rate: 29.970 fps
Standard: NTSC
The video dimension is 352*240 pixel.
You need to modify the following properties of subtitles:
1. font size/text height
2. Alignment-right, left or center
3. Position
4. Width and height
Each title is a movie. I have Five English(EN) SubRipText(*.srt) files for each of them. I need to add this subtitles to all five movies and re-author DVD with subtitles.
I tried most methods given in user guides. Subtitles are added to the videos. But they are not positioned well. I’ve tried DVDSubEdit. But I could not align them to center i.e. Subtitles are not center aligned. Also, They do not fit inside window. When I tried methods using DVD Lab Pro the subtitles are off screen (see image_1)
How would you add subs to this video using the following tools:
Pgcdemux, subtitle creator, subtitle workshop, ifoedit, vobblanker, DVD Lab Pro, DVDSubEdit etc.
Results 1 to 1 of 1
Adding Subtitles to MP4 Files
By elapid in forum SubtitleReplies: 13Last Post: 26th Nov 2015, 20:58 -
Adding subtitles from .VOB to MKV
By jstluise in forum SubtitleReplies: 5Last Post: 21st Sep 2012, 03:06 -
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 20:43 -
Question about DVD Authoring - Adding subtitles in a vertical orientation
By djash1983 in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2010, 21:56 -
adding subtitles to a DVD in VOB format
By marg52 in forum SubtitleReplies: 1Last Post: 16th Sep 2010, 10:55
