Just bought a refurbished PC to do some light gaming on. I'm trying to determine whether or not to upgrade my PSU. First I figured I better understand what makes a good power supply first. I've done a bit of research already and would like to confirm some things. I want to supply the needed wattage to my video card and from what I can tell this is supplied on the 12V rail. My questions:
1) If a 300W PSU has a 20A 12V rail, that is actually better than a 350W PSU with 18A on the 12V rail?
2) ANY video card that does not take a 6 pin PCI-e connector will draw at most only 75 watts of power?
3) Assuming #2 and a good brand name PSU, If I itemize all my wattage by hardware and am under 80 percent of any rail, then i should be ok, right.
Simple test. Run the present PC at 100% CPU shown from the Task Manager for at least a half hour.
Then check the heat exiting from the power supply. If it's 'hair dryer hot', you probably need a PS upgrade.
And if the same kind of heat is coming from the PC itself (CPU, etc.), you need more cooling.
I would recommend a 500 - 750 Watt PS. 500 is likely more than enough. 750 would be overkill, IMO, for most PCs.
But larger PS's have become more efficient and somewhat cheaper. -
You can use http://www.ocbase.com/ - multimeter (DMM) can be used to verify voltage quality (under load) - beware- DMM will not say everything about your PSU but it can be helpful to detect voltage drop.
Beware of ultra cheap power supplies. They often can't put out half their rated power before frying. If a mid range PSU costs much less than 10 cents (US) per watt it's probably trash. Stick with the big names.
Careful of that word.....REFURBISHED....... it can mean just about anything.
I learned a long time ago that certain cheap refurbished items become very expensive when they fail and kill other components. -
Thanks for the general understanding tools and tips! Actually haven't bought a Video Card yet either. Kind of confused on how to make a choice with that too... If I know the card only takes at most 75Watts(if no PCI-e Connector), why do manufacturers require different Amperage?
https://forum-en.msi.com/faq/article/power-requirements-for-graphics-cards
Seems to me, as long as the 75 watts is covered (~6.25A on 12V rail) then why would you need excess(understanding that I do not want to use more than 80% of any rail)? Of course I am assuming the wattage for the CPU and some other things in my estimate. -
Because they don't know which power supply you're going to use and how much power will be available on each rail. And they don't know exactly what else you'll have in your computer sucking up power. And they're probably aware that many ultra cheap PSUs can't output half the power they claim. And of course, all that is too complicated for most people to understand. So they over estimate the size of the PSU you will need to make sure you'll have enough.
Understanding Profiles
By whereswally007 in forum Video ConversionReplies: 4Last Post: 7th Oct 2013, 11:11 -
Understanding RAM: When is more better?
By beavereater in forum ComputerReplies: 4Last Post: 22nd Mar 2013, 06:53 -
Understanding 3D technology
By mbudman in forum Newbie / General discussionsReplies: 37Last Post: 31st Dec 2011, 13:22 -
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Any of you upgrade your power supplies?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 14Last Post: 16th Sep 2011, 22:36
