So pretty much the color is really off on the encode and I can't figure out why and yes I am a noob at this so I wouldn't advise saying anything without an explanation because then I'll just ask how do I do that
Here are some screens to show what I'm talking about
http://screenshotcomparison.com/comparison/141520
http://screenshotcomparison.com/comparison/141521
http://screenshotcomparison.com/comparison/141522
And here are my encoding settings, the AVS script was nothing special, only put in the Crop and Spline36Resize commands with FFDIndex Source.
http://imgur.com/a/DlyvN#0
Btw if you're confused about the colormatrix setting because it wasn't in the original 4 settings logs then just to let you know I did use bt709 for color matrix, it just wasn't in the first four images cause I did another encode without bt709.
				Results 1 to 1 of 1
  Color change after encodeBy Tylerr in forum Video ConversionReplies: 8Last Post: 7th Jan 2015, 08:31
  Premier: can I encode several chunks, then compile to Bluray disc?By engineerer in forum Newbie / General discussionsReplies: 10Last Post: 30th Apr 2014, 00:30
  Leawo bluray/DVD creator issuesBy Exfso in forum Video ConversionReplies: 4Last Post: 15th May 2013, 21:21
  Disney 3D BluRay ripping issuesBy enderwiggin in forum Blu-ray RippingReplies: 15Last Post: 24th Mar 2013, 20:43
  Bluray remux and Bluray re-encode questionBy mocqueanh in forum Blu-ray RippingReplies: 4Last Post: 22nd Feb 2011, 21:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
