Hi,
I've been looking around for a very simple softaware I can use to EQ the audio in a video file and maybe normalize it (could be done separately though) and save it either in any of the more common file formats (the same as the original file, -mov in this case, or wmv, mpg would be ok).
I need it to be a decent EQ, not something where 100Hz on a graphic EQ is the lowest freqency that can be altered, I need fullrange control. Preferably a parametric EQ, but a graphic will do.
I'm pretty much an idiot when it comes to software, so it needs to be pretty easy to use. I'll gladly pay for a good working software, but it needs to have a fully working trail version so I can actually see it works. I've tried a couple that didn't work (MP4Gain looked promising, but I can't save files in the trail version, so no way of knowing, Lightworks was to demanding for my PC, Sony Vegas was just way to complicated).
Is there really nothing out there that actually works and is about as simple as a media player where I can press "save" after adjusting the EQ?
If only Audacity or WaveLab could handle video files...
Any ideas about watching a video signal in simple clean software like vlc..
By noelennon in forum Newbie / General discussionsReplies: 2Last Post: 5th Jul 2014, 16:38 -
Edit snippets of audio out of a video file--simple way?
By hech54 in forum EditingReplies: 14Last Post: 10th Apr 2014, 21:44 -
Simple Software to record video from my webcam
By herscht in forum Capturing and VCRReplies: 5Last Post: 29th Aug 2012, 11:29 -
Advice for simple, free video-editing software for a newbie
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2011, 22:25 -
Need simple software to extract video portions from .avi movies
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2011, 11:01
