Hi, I have some troubles with audio and video not being synced when I convert a TV Show episode with Any Video Converter. I have tried several settings:
Resolution: 624x352
Quality: High
Video codec: x264
Vid. bitrate 2000
FPS 23
1. mp3 - .avi
audio bitrate 256
sample rate 32000
2. mp3 - .avi
AB 192
SR 48000
3. mp3 - .avi
AB 128
SR 8000
4. mp3 - .avi
AB 320
SR 32000
These four tests came back same (or closely same) but the video is still not synced. I just changed audio settings for files obviously. The problem comes when I try to add subtitles and convert it. Without converting it works great and synced. I'm trying to play it on a Terrestrial receiver Globo GL30. I did a firmware update on it and still same. I made sure resolution and FPS are same on original file and converted file. Thanks for any help.
When you get that close you have to run it in slow motion to tell for sure. Persistence of vision can fool you. (If you want to see an example watch an academy countdown leader. When it's properly synced you will hear the beep while the indicator appears to show ~two frames left of the "3.")
[Attachment 33497 - Click to enlarge]Last edited by smrpix; 5th Sep 2015 at 10:29.
I might try it out but I'm pretty satisfied with this one to hassle so much over that 2-3 fps difference between audio and video. Thanks for the video, though I would get something longer than 2 seconds not to press play over and over :P
Thanks.
audio video not synced
By zoranb in forum Capturing and VCRReplies: 13Last Post: 6th Mar 2014, 00:55 -
How to synced video in Avidemux?
By FaisalKhan in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2011, 04:08 -
how audio can be synced?
By FaisalKhan in forum Newbie / General discussionsReplies: 4Last Post: 28th Jul 2011, 10:11 -
Synced audio track on MKV eventually becomes out off sync
By brent1a in forum Video ConversionReplies: 2Last Post: 18th Nov 2010, 14:28 -
Synced audio track eventually becomes out off sync
By brent1a in forum AudioReplies: 1Last Post: 18th Nov 2010, 13:58
